Mercedes Brembo calipers on E body? #2749730
03/06/20 11:33 PM
03/06/20 11:33 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
Good evening everyone
The other day I was out at my local U pull it yard. I noticed I'm the truck are was a Mercedes ML155 AMG. Looking at this SUV, I noticed the front calipers were 4 piston Brembo and the rear were 2 piston Brembos
I grabbed them thinking they might work good to modernize the my Cuda (and they were $13.00 a piece). So has anyone used these or Brembos on old mopars? If so what rotor have you used?
Any help or ideas are greatly appreciated
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Mercedes Brembo calipers on E body? [Re: TX9H6E4CUDA] #2749743
03/07/20 12:24 AM
03/07/20 12:24 AM
AndyF Offline
AndyF  Offline
Ear mount makes it difficult to do. If they were radial mount then it would be a lot easier. I've built a bunch of custom brake kits over the years but I don't use ear mount calipers anymore since it is too much work.
Re: Mercedes Brembo calipers on E body? [Re: AndyF] #2758853
04/02/20 01:03 PM
04/02/20 01:03 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
maybe put them on ebay and buy some viper ones.
ebay mb brembo brake calipers
perception is 90% of reality
Re: Mercedes Brembo calipers on E body? [Re: TX9H6E4CUDA] #2775153
05/16/20 03:01 PM
05/16/20 03:01 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can use them if you like. Nothing wrong with that.
The fronts are designed to fit 13-1/2" rotors that are 1-1/4" thick. The rears are designed for 13" solid rotors 1/2" thick.
I would strongly suggest looking for rotors before going any farther. It might be difficult to find something that fits your car. Should you find luck there, it's all about building the brackets. That can be the tricky bit.
If you have the fabrication skills it is entirely possible. It's the time and trouble you need to consider. If it turns out to be a bit more work than you're comfortable doing then flipping them on Ebay might work but you shouldn't expect a big dollar. There are far more attractive calipers available.
Those calipers are essentially the same as the non-AMG models used through those years but the mounting ears are different. Early SRT-8 cars wore similar parts.
Do not split the caliper. The o-rings are not available. Turn those torx head bolts and you've got a paperweight.
- Stu Harmon
Re: Mercedes Brembo calipers on E body? [Re: feets] #2813886
08/27/20 10:35 AM
08/27/20 10:35 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Mustang rotors seem to be common, there is a guy on Dodgecharger.com that was selling a bracket to mount them. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
