Re: Hobo Fright CAR DOLLIES ... what say you ??
[Re: Pacnorthcuda]
#2749675
03/06/20 07:42 PM
03/06/20 07:42 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Those ones that they're selling this weekend for $39 a pair, no good for a Mopar. I have four of those. Once you get some weight on them they deflect enough that the casters don't work good. The ones that have the foot pedal to jack them up are pretty decent. I have a set of four of those and no complaints. Even under some pretty heavy vehicles.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: kidmopar]
#2749686
03/06/20 08:23 PM
03/06/20 08:23 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don’t forget to get your free LED flashlight.
[Re: kidmopar]
#2749687
03/06/20 08:36 PM
03/06/20 08:36 PM
Posts: 30,488 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
"HOBO FRIGHT" ? ? ? ? That name is the fault of the neighbor of the above this post ..... Harbor Freight The two Pennsylvania that HOARD these lights !
[Re: dOc …]
#2749690
03/06/20 08:41 PM
03/06/20 08:41 PM
Hemi_Joel
Minnesota
good for rolling around an engine block. B body, not so good.
[Re: mccannix]
#2749709
03/06/20 09:18 PM
03/06/20 09:18 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don’t forget to get your free LED flashlight. Hazard Fraught has replaced those with these. Maybe in your neck of the woods. We still have the good stuff here in pa.
[Re: mccannix]
#2749710
03/06/20 09:25 PM
03/06/20 09:25 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I put 4 under my sons 67 Dart 270. Could NOT roll the front end at all. The rear was movable but not smoothly.
I took 5 of the $12 wood movers dollies, took 1 apart and put two more of the swivel wheels under 4 of them to make four each into 6 swivel wheel ones, and this works well. The steel ones I use for my engine blocks. I just welded some steel strap on so the blocks sit square. They roll around real well.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: moetown]
#2749717
03/06/20 09:38 PM
03/06/20 09:38 PM
Posts: 5,949 ohio
ruderunner
ohio
I bought a set of the heavy duty ones. No problem moving my Ramcharger around on them. It has front and rear Dana 70 axles and 36 inch swampers.
Those are not what's on sale though.
Angry white pureblood male
[Re: Hemi_Joel]
#2749727
03/06/20 10:48 PM
03/06/20 10:48 PM
Posts: 28,621 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
good for rolling around an engine block. B body, not so good. I put them under the Dart as it just sits with low miles. So close to one wall. I pushed it over so I could work on it No Go. I did better with a floor jack. I may try the larger ones but those were junk. Would not move! You would have thought my mother in law was in tha car
[Re: 340SIX]
#2749732
03/06/20 11:52 PM
03/06/20 11:52 PM
dOc …
Florida STAYcation
good for rolling around an engine block. B body, not so good. I put them under the Dart as it just sits with low miles. So close to one wall. I pushed it over so I could work on it No Go. I did better with a floor jack. I may try the larger ones but those were junk. Would not move! You would have thought my mother in law was in tha car So Pinkster ... you tried to CHEAP OUT with the 1000 pounders instead of the 1500 ones? Your mother in law ...
[Re: dOc …]
#2749741
03/07/20 12:12 AM
03/07/20 12:12 AM
Dave_J
Auburn WA
I took 5 of the $12 wood movers dollies, took 1 apart and put two more of the swivel wheels under 4 of them to make four each into 6 swivel wheel ones, and this works well. The steel ones I use for my engine blocks. I just welded some steel strap on so the blocks sit square. They roll around real well. The movers dollies ? So the wooden ones have a better quality caster wheels ? With 6 castors under then yes.
