Re: 74 Charger Door Adjust
[Re: 71vert340]
#2749609
03/06/20 03:47 PM
03/06/20 03:47 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Good question. I thought these were worked rear to front. You can't move the quarter, so you set the door to that. Then the fender to where the door is. Not a body guy, just what I had seen done. Cool project, by the way.
[Re: 71vert340]
#2749636
03/06/20 05:17 PM
03/06/20 05:17 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Yes, that's the way I've always done it in the past on my Challengers. The quarter panels are the "set to" as long as they haven't been replaced. I've owned this car for over 30 years and it's always been this way. I replaced the striker with new ones. Tried to shift it , looked down in the quarter panel and noticed I'm out of adjustment. I could leave it like it is, but would prefer to fix this prior to painting. The door gaps and front fender to door and to hood gaps are great. Thanks for the feedback. Terry I wonder if the new striker isn't made to same dimensions as original. Do you have the original parts to swap in for a quick check?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: 71vert340]
#2749765
03/07/20 08:20 AM
03/07/20 08:20 AM
Posts: 5,711 ohio
ruderunner
ohio
Now you get to make the windows fit!
Angry white pureblood male
