Re: Rolling car help
[Re: fowl play]
#2748792
03/03/20 10:19 PM
03/03/20 10:19 PM
Posts: 289 Lowes
steve660
Lowes
Cold, my car was the same way. Almost impossible to push. But after i make a pass i can push it easily. I think its the tight clutch pack in transmission??.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: fowl play]
#2748795
03/03/20 10:48 PM
03/03/20 10:48 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My son had an issue with his line lock that was causing his front factory disk brakes to drag. He disconnected it two years ago and all is well
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Exit1965]
#2749144
03/05/20 12:24 AM
03/05/20 12:24 AM
Posts: 7,545 Minnesota
Hemi_Joel
Minnesota
Not a race car, but my 67 GTX convert is hard to push. 727 trans, 8-3/4, drum brakes, 50,000 original miles. I made sure the brakes are not dragging. I think it's something in the trans. I'll be watching here.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2749157
03/05/20 05:19 AM
03/05/20 05:19 AM
Posts: 10,051 MI, usa
dvw
MI, usa
The car will be harder to push rearward due to more internal components rotating in the trans when the output is turned counter clockwise. Even though my trans is mostly roller bearing, it is still very tough to push. Yet on the hoist you can rotate the drive shaft with one hand (spool, axles. brakes, wheels/tires installed). Doug
[Re: dvw]
#2820764
09/14/20 07:07 PM
09/14/20 07:07 PM
Posts: 43,913 Bend,OR USA
Cab_Burge
Mine wouldn't even roll down the hill in the staging lanes at Dragway 42. Loosened upped the Will wood brakes. Rolls easy. Made ZERO difference in ET. I've had the front Will woods apart numerous times. The strange part is only the front pair stick. Never the rears. Doug Does the Master cylinder have a residual valve for drum brakes in it? If so it will hold close to 10 Lb. pressure on them
