smoking ballast #2749103
03/04/20 11:01 PM
03/04/20 11:01 PM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
Having issues with my 71 GTX, 440-6 4 speed. Car was running fine on a recent drive. On the way home it started missing and proceeded to get much worse. It got so bad I decided to just park it and get it towed home. I figured it ate the points so I put a new set in and it wouldn't start. After messing around with it I discovered no spark coming from the coil. I then installed a new coil but lo and behold, still no spark. I started going through a diagnostic evaluation (instead of just throwing parts at it) and I really couldn't narrow it down. Points are good, condenser checked out, rotor checked out. Voltage at the coil was 11.8 with key in run position, 9.6 or so in the start position. Without really fixing anything car then started and ran fine. I then decided to drive it around and it ran fine for about 5 minutes and then started missing severely. Car died a couple of times trying to get it home and then when I limped it onto my street, it smoothed out and started running o.k. again. I got home and did the only thing I could think of. I got a cold beer and just looked at the car for awhile. I started thinking that something must be getting hot?? and shorting out in the ignition system. I have many new ballast resistors in stock so I placed a new ballast on the car. I checked ohms resistance on the new ballast before installing and it was .6-.7 ohms. It started right up and was running fine in the garage. I was under the hood just looking and noticed that after running for a minute or so the new ballast started smoking. I shut the car off and there it sits. I then finished my beer.
I'm thinking the problem is in the ignition run circuit (the Blue wire that comes out of the ignition switch and ultimately is on the run side of the ballast and is also one of the field wires off the back of the alternator).
Re: smoking ballast [Re: 2JcodeChargers] #2749114
03/04/20 11:30 PM
03/04/20 11:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The blue wire feeds the resistor for the ignition . So any excessive draw would be from the ignition side. The regulator and alternator are fed on the same input side or supply side to the resistor. The charging system is not on the resistor side. The resistor will get hot and a new one may smoke until the coating wears off. Try a new condenser. I have seen many failures. Also make sure the distributor lead is not grounding out in the distributor attachment area or condenser lead. Also make sure the coil is for an external resistor.
Re: smoking ballast [Re: NITROUSN] #2749130
03/05/20 12:36 AM
03/05/20 12:36 AM
condensor
Re: smoking ballast [Re: RapidRobert] #2749133
03/05/20 12:49 AM
03/05/20 12:49 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Originally Posted by RapidRobert
condensor
Sounds like an intermittent continuity issue on the primary side.
Making-Breaking Contact. Worst after some time (i.e. heating).
Condition on those wirings & connections?
Old/New wiring harness?
Higher rpm == higher amp load on ignition circuit.
May run OK at idle, then crappy otherwise.
If/When you have it idling OK, wiggle wiring & observe.
Re: smoking ballast [Re: 2JcodeChargers] #2749151
03/05/20 02:59 AM
03/05/20 02:59 AM
You need to check it with your volt ohm meter when it gets hot and acts so you can trouble shoot it properly wrenchscope
It might be the wires under the dash to the bulkhead connector or from the bulk head connector up to the resistor or some where else scope
Look for the voltage drop first and then for higher resistance twocents
It is repeating now so go find it up grin
Re: smoking ballast [Re: Cab_Burge] #2749225
03/05/20 11:36 AM
03/05/20 11:36 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
iagree Check the connector at the base of the steering column. Mine was loose fitting and caused the engine to misfire and die. Luckily my foot brushed against that connector when I got out of the car and the engine misfired. If that wouldn't have happened, who knows how long I would have been chasing that issue. It could also be any connection on that run wire. Check them all.
Re: smoking ballast [Re: burdar] #2749242
03/05/20 12:29 PM
03/05/20 12:29 PM
moparx Offline
moparx  Offline
i second the steering column connector.
i have repaired a fair amount of those that have gotten "melty" over the years. sometimes they are hard to see.
beer
Re: smoking ballast [Re: 2JcodeChargers] #2749249
03/05/20 12:58 PM
03/05/20 12:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
The above is not totally uncommon as they do get pretty hot. Any residue on them will cause them to smoke for a short time. Otherwise I would say a flaky condenser or connection. Check the ends of the coil wire, I was chasing an intermittent ignition problem one time and found a bad connection on one end of the coil wire. It had been arcing for awhile and burnt the cap and center conductor quite aways up inside the wire. smile
Re: smoking ballast [Re: TJP] #2749365
03/05/20 06:57 PM
03/05/20 06:57 PM
post what it ends up being
Re: smoking ballast [Re: RapidRobert] #2749371
03/05/20 07:04 PM
03/05/20 07:04 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Maybe the coil is simply drawing too much current??? I agree that really hot ballasts are not uncommon.
