ladder bar set up's #274901
04/02/09 10:45 AM
04/02/09 10:45 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
anyone here have a pic of there ladder bar set up? i believe i have to go to a coil over set up to do this which means i remove the leaf springs, but i don't understand what holds the rear end in the car without the leaf springs.
Re: ladder bar set up's [Re: mopar dave] #274902
04/02/09 10:51 AM
04/02/09 10:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The coil over shock holds the body up. The coil spring
is pushing on both ends of the shock causing it to
extend, if you have the correct spring weight on the
shock it will compress the shock to its designed length
Re: ladder bar set up's [Re: MR_P_BODY] #274903
04/02/09 11:09 AM
04/02/09 11:09 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Re: ladder bar set up's [Re: gsmopar] #274904
04/02/09 12:00 PM
04/02/09 12:00 PM
Mt Morris Michigan
Mt Morris Michigan
will the upper stock shock mount have to be reinforced to hold the weight of the car?
Re: ladder bar set up's [Re: mopar dave] #274905
04/02/09 12:41 PM
04/02/09 12:41 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Yes. I'd buy or fab up a shock mount. Are you doing a full back half or just want ladder bars on the stock axle?
Post deleted by moparts [Re: gsmopar] #274906
04/02/09 12:46 PM
04/02/09 12:46 PM
Re: ladder bar set up's #274907
04/02/09 01:26 PM
04/02/09 01:26 PM
Mt Morris Michigan
Mt Morris Michigan
nice duster. i would like to do ladders on stock axle.
Re: ladder bar set up's [Re: mopar dave] #274908
04/02/09 06:37 PM
04/02/09 06:37 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
If you're using a stock axle and I assume a stock floor pan you'll need to look for a fairly short coil over shock and fab up a mount if you want to keep it all under the trunk. I've done the mini tub ladder bar set up before and honestly it was more work than just doing a full back half.
Re: ladder bar set up's [Re: gsmopar] #274909
04/02/09 07:40 PM
04/02/09 07:40 PM
HERES a picture on my 65 coronet
Re: ladder bar set up's #274910
04/03/09 08:00 AM
04/03/09 08:00 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks guys. maybe i should go the cal track route instead. ladders look more trick.
Re: ladder bar set up's [Re: gsmopar] #274911
04/03/09 09:17 AM
04/03/09 09:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont need to go to a short shock... lower the mount
on the axle, if you want you can go as low as the
bottom of the ladder bar mount, if you go that low
move the shock back a little more for the added
movement in the longer bracket(rotational).
Re: ladder bar set up's [Re: MR_P_BODY] #274912
04/03/09 10:21 AM
04/03/09 10:21 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
It is ALOT more work, but I have at least 6" of height adjustabilty w/16" coilovers and it all fits under the stock floor, sort of. I can even install the back seat if I need to. It works really well so I'd say I'd probably do it again.'68 Coronet...
Re: ladder bar set up's [Re: Bill MeLater] #274913
04/03/09 10:45 AM
04/03/09 10:45 AM
Mt Morris Michigan
Mt Morris Michigan
i have'nt ruled out ladders just yet. this will be a fall winter project, so i have all this season to get some idea's and decide. going to have fun playing and dialing in what i got for now.
