Best stock intake??? #2748591
03/03/20 02:00 PM
03/03/20 02:00 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Anyone done any back to back testing on the stock intakes? Flow bench, drgastrip or actual dyno testing? I am curious what would be the best ones if hood clearance and such are not an issue, does the flat runners on the front of an SRT 6.4 intake make less power than a truck intake with straighter butt longer runners? Does a ported 6.1 flow as much and I know they run a lot hotter, how much does heat soak affect it? I know the eagle intake is pretty good but it is sharper curves and smaller port size, just how good/bad is it compared to the different 6.4 intakes?
Re: Best stock intake??? [Re: HotRodDave] #2748610
03/03/20 02:53 PM
03/03/20 02:53 PM
ghinmi Offline
ghinmi  Offline
It is my understanding that the truck 5.7 intake is essentially the same as the car 6.4 minus the inlet location. The intake was developed for the 5.7 trucks and then had the inlet modified for the 6.4 cars. The 6.4 car intake has the worst distribution of all gen3 hemi intakes.
I would love to see someone test the truck 6.4 intake as that one has the most drastically different runners and plenum (larger).
Best is a relative term, there is no one intake that is best for all gen3 applications.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Best stock intake??? [Re: ghinmi] #2748627
03/03/20 03:26 PM
03/03/20 03:26 PM
Kalispell Mt.
Kalispell Mt.
The eagle truck and 6.4 car intake are quite different, the front runners on the car intake are smashed for hood clearance, the truck ones are not, the truck eagle intake has smaller runners that are not as good a match for the SRT heads butt they are not smashed in the front.
Re: Best stock intake??? [Re: ghinmi] #2748825
03/04/20 07:05 AM
03/04/20 07:05 AM
Australia
L4staero Offline
L4staero  Offline
Australia
This was the MMX results with the 6.4 truck manifold vs car
87846093_1503428219819059_2147746182170935296_o.jpg87894262_1503428306485717_6699035687582171136_o.jpg
Re: Best stock intake??? [Re: L4staero] #2748930
03/04/20 01:47 PM
03/04/20 01:47 PM
Kalispell Mt.
Kalispell Mt.
I'm struggling to decipher what I'm looking at, is it BGE 6.4 intake VS SRT 6.4 intake? Witch line is witch?
Re: Best stock intake??? [Re: HotRodDave] #2748978
03/04/20 04:13 PM
03/04/20 04:13 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Yes 6.4 truck vs 6 4 car intake. Truck manifold is the higher output
Re: Best stock intake??? [Re: L4staero] #2749014
03/04/20 06:38 PM
03/04/20 06:38 PM
IL
furious70 Offline
furious70  Offline
IL
what engine was that on tho? Eagle 5.7, BGE 6.4 or SRT 6.4?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Best stock intake??? [Re: furious70] #2749018
03/04/20 06:53 PM
03/04/20 06:53 PM
Kalispell Mt.
Kalispell Mt.
I don't think a 5.7 could make that much TQ, Im thinking BGE. I'm gonna start looking for one for my truck.
Re: Best stock intake??? [Re: HotRodDave] #2749173
03/05/20 08:51 AM
03/05/20 08:51 AM
ghinmi Offline
ghinmi  Offline
I'll bet it's a 5.7, those torque numbers don't seem unattainable.
Re: Best stock intake??? [Re: ghinmi] #2749280
03/05/20 02:03 PM
03/05/20 02:03 PM
Kalispell Mt.
Kalispell Mt.
I wouldn't say it is impossible but that is 1.34 LBS per CID
BES engine master 400 Hemi made 1.24 and it was really good so it would need to be a very very well built 5.7 to do that and probably a happy dyno unless I am totally missing something.
Re: Best stock intake??? [Re: HotRodDave] #2749309
03/05/20 03:55 PM
03/05/20 03:55 PM
IL
furious70 Offline
furious70  Offline
IL
Does the BGE intake help an eagle 5.7 then? Or is the 16+ 5.7 truck manifold the best if you have the hood clearance?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Best stock intake??? [Re: HotRodDave] #2749378
03/05/20 07:17 PM
03/05/20 07:17 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Stay tuned I will being doing just that!
Need to get a Terminator X max from Holley because Summit doesn't have them. WTH?
The bottom end is a 3.79 stroke .020 over 5.7
It has a 6.1 cam in it.
This was supposed to be for a project that never took off.
Heads are semi ported 5.7 early heads.
Intakes I have are.
Drag pack
CASCAR Prefix
old truck intake.
6.1 intake
drag pack and CASCAR obviously i will be using a carb.
Have long tube headers and factory SRT headers.
Hopefully in a couple of months I'll have some results.
Re: Best stock intake??? [Re: MattW] #2749420
03/05/20 09:22 PM
03/05/20 09:22 PM
Kalispell Mt.
Kalispell Mt.
I wonder the best way to ship you a mess of intakes, I have car and truck early 5.7s and car and truck eagle intakes. My truck 6.4 intake is burned on the top so no use but to look at. I guess only the early car intake will fit your block, the 6.4 truck intake looks like it will fit an early block, doubt an SRT 6.4 will fit it butt maybe. I think only the BGE, 6.1 early car, and early truck intakes fit your earlier block (I assume your running an early block because of the 6.1 cam).
Re: Best stock intake??? [Re: HotRodDave] #2749540
03/06/20 12:16 PM
03/06/20 12:16 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Early 5.7
You have a PM
Matt
Your PM is full.
Send me a text # to my PM box
Re: Best stock intake??? [Re: MattW] #2749707
03/06/20 09:18 PM
03/06/20 09:18 PM
Australia
aus370 Offline
aus370  Offline
Australia
Wonder if it's possable to modify the 6.4 truck intake , by chopping the angled throttle body section off . then making adaptor to for straight TB , then lock it in short runner position.
