Re: Rolling car help [Re: fowl play] #2748792
03/03/20 11:19 PM
03/03/20 11:19 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Cold, my car was the same way. Almost impossible to push.
But after i make a pass i can push it easily.
I think its the tight clutch pack in transmission??.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Rolling car help [Re: fowl play] #2748795
03/03/20 11:48 PM
03/03/20 11:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My son had an issue with his line lock that was causing his front factory disk brakes to drag. He disconnected it two years ago and all is well
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Rolling car help [Re: fowl play] #2748875
03/04/20 10:28 AM
03/04/20 10:28 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Too much camber or toe
Boffin Emeritus
Re: Rolling car help [Re: polyspheric] #2749143
03/05/20 01:15 AM
03/05/20 01:15 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I noticed my car was harder to push backwards than it had been, at the same time had a small differential leak. I took the driveshaft out and found the pinion nut just hand tight. I put a new nut on, with loctite, around 250 ftlbs, and it was then back to normal in terms of how hard it is to push, and no more leak. I also engraved the pinion and nut so that I can look in and see that the nut is where it was when torqued in.
Re: Rolling car help [Re: Exit1965] #2749144
03/05/20 01:24 AM
03/05/20 01:24 AM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
Not a race car, but my 67 GTX convert is hard to push. 727 trans, 8-3/4, drum brakes, 50,000 original miles. I made sure the brakes are not dragging. I think it's something in the trans. I'll be watching here.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Rolling car help [Re: Hemi_Joel] #2749157
03/05/20 06:19 AM
03/05/20 06:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The car will be harder to push rearward due to more internal components rotating in the trans when the output is turned counter clockwise. Even though my trans is mostly roller bearing, it is still very tough to push. Yet on the hoist you can rotate the drive shaft with one hand (spool, axles. brakes, wheels/tires installed).
Doug
Re: Rolling car help [Re: dvw] #2749162
03/05/20 07:41 AM
03/05/20 07:41 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
If you have a spool that's the reason for it being hard to push even for 3 people, prior to the spool i could push the car by myself.
Re: Rolling car help [Re: RATTRAP] #2749288
03/05/20 02:32 PM
03/05/20 02:32 PM
Sounds like your rear tires are not the same diameter based on pushing harder now with the spool compared to before work scope
I used a cloth seamstress tape to measure the circumference of all my tires regardless if going on a spool rear end or not twocents up
Re: Rolling car help [Re: fowl play] #2820242
09/13/20 02:20 PM
09/13/20 02:20 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Did you ever figure out the problem ?
Re: Rolling car help [Re: dvw] #2820489
09/14/20 07:10 AM
09/14/20 07:10 AM
Indiana
68_661charger Offline
Indiana
My car was always hard to push and it turned out that the pinion nut was too tight and the crush sleeve was crushed too much.
Re: Rolling car help [Re: dvw] #2820764
09/14/20 08:07 PM
09/14/20 08:07 PM
Originally Posted by dvw
Mine wouldn't even roll down the hill in the staging lanes at Dragway 42. Loosened upped the Will wood brakes. Rolls easy. Made ZERO difference in ET. I've had the front Will woods apart numerous times. The strange part is only the front pair stick. Never the rears.
Doug
Does the Master cylinder have a residual valve for drum brakes in it? scope If so it will hold close to 10 Lb. pressure on them shruggy
