Lowering a 66 D200
#2748632
03/03/20 03:37 PM
03/03/20 03:37 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Asking for a friend. He has a 66 D200. Wants to lower it. He knows about flipping the rear axle however nor sure how hw would do the front axle. His concern I’d the position of the drag link in relation to the axle. Any ideas?
Abe Lincoln
Re: Lowering a 66 D200
[Re: dart4forte]
#2748824
03/04/20 06:38 AM
03/04/20 06:38 AM
Posts: 5,775 ohio
ruderunner
ohio
How much does he want to lower it?
A rear axle flip will get about a 6 inch drop. That much in the front would put the axle against the oil pan.
Angry white pureblood male
[Re: dart4forte]
#2748843
03/04/20 09:21 AM
03/04/20 09:21 AM
Posts: 1,335 Oregon
earlymopar
On my 65 D100, I achieved what measured to be a 6" drop in the rear just by changing the rear spring hangers. This was 5 years ago and at the time, the aftermarket hanger I used was purchased from Autozone of all places.I don't recall the brand. The strange thing was the drop I achieved was greater than the difference between the OEM and aftermarket hangers.
On the front end, I wanted to stay with the factory dropped axle but I sent it out and had it dropped an additional 3". For me that was perfect. The D100 in that era uses a 4-spring / side arrangement. I believe the D200 uses 5 or more so he might consider removing a leaf (or maybe more).. The solution to the draglink is to change to a slight shorter pitman arm from a W100 (I believe that's correct). I have a new one if your friend is interested.
- EM
[Re: earlymopar]
#2748860
03/04/20 09:48 AM
03/04/20 09:48 AM
dart4forte
Mesa, Arizona
- EM
Wouldn’t you also need a shorter idea arm as well?
Abe Lincoln
[Re: earlymopar]
#2749039
03/04/20 08:13 PM
03/04/20 08:13 PM
dart4forte
Mesa, Arizona
- EM
What size are those wheels and tires?
Abe Lincoln
