Re: Best stock intake???
[Re: HotRodDave]
#2748610
03/03/20 02:53 PM
03/03/20 02:53 PM
Posts: 112 Michigan
ghinmi
It is my understanding that the truck 5.7 intake is essentially the same as the car 6.4 minus the inlet location. The intake was developed for the 5.7 trucks and then had the inlet modified for the 6.4 cars. The 6.4 car intake has the worst distribution of all gen3 hemi intakes.
I would love to see someone test the truck 6.4 intake as that one has the most drastically different runners and plenum (larger).
Best is a relative term, there is no one intake that is best for all gen3 applications.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: HotRodDave]
#2748978
03/04/20 04:13 PM
03/04/20 04:13 PM
Posts: 146 Australia
L4staero
Australia
I'm struggling to decipher what I'm looking at, is it BGE 6.4 intake VS SRT 6.4 intake? Witch line is witch? Yes 6.4 truck vs 6 4 car intake. Truck manifold is the higher output
[Re: L4staero]
#2749014
03/04/20 06:38 PM
03/04/20 06:38 PM
Posts: 2,255 IL
furious70
IL
what engine was that on tho? Eagle 5.7, BGE 6.4 or SRT 6.4?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: HotRodDave]
#2749173
03/05/20 08:51 AM
03/05/20 08:51 AM
Posts: 112 Michigan
ghinmi
I'll bet it's a 5.7, those torque numbers don't seem unattainable.
[Re: HotRodDave]
#2749309
03/05/20 03:55 PM
03/05/20 03:55 PM
Posts: 2,255 IL
furious70
IL
Does the BGE intake help an eagle 5.7 then? Or is the 16+ 5.7 truck manifold the best if you have the hood clearance?
[Re: HotRodDave]
#2749378
03/05/20 07:17 PM
03/05/20 07:17 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Anyone done any back to back testing on the stock intakes? Flow bench, drgastrip or actual dyno testing? I am curious what would be the best ones if hood clearance and such are not an issue, does the flat runners on the front of an SRT 6.4 intake make less power than a truck intake with straighter butt longer runners? Does a ported 6.1 flow as much and I know they run a lot hotter, how much does heat soak affect it? I know the eagle intake is pretty good but it is sharper curves and smaller port size, just how good/bad is it compared to the different 6.4 intakes? Stay tuned I will being doing just that! Need to get a Terminator X max from Holley because Summit doesn't have them. WTH? The bottom end is a 3.79 stroke .020 over 5.7 It has a 6.1 cam in it. This was supposed to be for a project that never took off. Heads are semi ported 5.7 early heads. Intakes I have are. Drag pack CASCAR Prefix old truck intake. 6.1 intake drag pack and CASCAR obviously i will be using a carb. Have long tube headers and factory SRT headers. Hopefully in a couple of months I'll have some results.
[Re: HotRodDave]
#2749540
03/06/20 12:16 PM
03/06/20 12:16 PM
MattW
Ontario Canada
Early 5.7 You have a PM Matt
Your PM is full. Send me a text # to my PM box
[Re: MattW]
#2749707
03/06/20 09:18 PM
03/06/20 09:18 PM
Posts: 80 Australia
aus370
Australia
Wonder if it's possable to modify the 6.4 truck intake , by chopping the angled throttle body section off . then making adaptor to for straight TB , then lock it in short runner position.
