Powder coating chassis #274854
04/02/09 08:19 AM
04/02/09 08:19 AM
SD800 Offline OP
SD800  Offline OP
Guys need to know if my mild steel full tube chassis will certify if I powder coat it, looking for it to certify to 7.50
You'll have plenty of time to sleep when your dead, let's go
Re: Powder coating chassis [Re: SD800] #274855
04/02/09 08:33 AM
04/02/09 08:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont see why not, he will scrape the coating off
in 1 place to get a true reading then he will just
subtract the coating thickness, that what he did with
my painted chassis. Yoy might find it harder to see
cracks in the chassis with the powder coating but I
dont know for sure
Re: Powder coating chassis [Re: SD800] #274856
04/02/09 06:15 PM
04/02/09 06:15 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Mild steel should be OK. I wouldn't powder coat a 4130 chassis as the heat treat characteristics start changing at around 450°F. I have a Metals Handbook that shows a drop in strength for 4140 (I know it's not the exact same alloy) and also toughness. Strange property to lose both as they usually go in opposite directions. There are some lower temperature powder coating materials available to keep it under 400°F.
Floyd Lippencott IV
Re: Powder coating chassis [Re: mr_340] #274857
04/02/09 07:28 PM
04/02/09 07:28 PM
Hershey,PA
mracer360 Offline
mracer360  Offline
Hershey,PA
Most powder coatings cure at 375 degrees F or below, some as low as 300.
Re: Powder coating chassis [Re: mracer360] #274858
04/02/09 10:50 PM
04/02/09 10:50 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
http://www.rohmhaas.com/wcm/products/product_detail.page?product=1120236&application=1120039
You are right, most I found were below 400 F. They must have come down in curing temperatures over the last ten years since I had any done. This one was 500 F, but is not typical. How good are the ovens to control the temperature?
Floyd Lippencott IV
Re: Powder coating chassis [Re: mr_340] #274859
04/03/09 02:51 PM
04/03/09 02:51 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
The ovens are so damn complicated now, they can control everything, humidity, temp, time, etc. Thats part of the reason they cost a fortune.
Re: Powder coating chassis [Re: The Avg. Valiant] #274860
04/03/09 02:59 PM
04/03/09 02:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a intake powder coated, the process called for
325 and it was dead on for the time to cook with in
a couple degrees.
I also have seen power coated chassis being certed
when I got mine done the last time... he passed
Re: Powder coating chassis [Re: MR_P_BODY] #274861
04/03/09 04:58 PM
04/03/09 04:58 PM
Kentucky
72 Dodge demon Offline
Kentucky
I had mine certified and then powdercoated it. Then he came back and put on the sticker. I tried
to send a picture but it is to big Look on dragracecity.com under new delay box cars. I have a picture of the chasis tag at the door
Re: Powder coating chassis [Re: 72 Dodge demon] #274862
04/03/09 11:55 PM
04/03/09 11:55 PM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Mine was just cirt last mounth, it is hammer toned powder coated and it pasted just fine.
(three years)
JoWeTu_6
Re: Powder coating chassis [Re: JoWeTu_6] #274863
04/03/09 11:57 PM
04/03/09 11:57 PM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Close up.
JoWeTu_6
Re: Powder coating chassis [Re: JoWeTu_6] #274864
04/04/09 12:01 AM
04/04/09 12:01 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Weeeeeeeee
JoWeTU_6
Re: Powder coating chassis [Re: SD800] #274865
04/06/09 09:04 PM
04/06/09 09:04 PM
Illinois
Ted P Offline
Ted P  Offline
Illinois
It will cert. for the NHRA. I do certs in the chicago area. I was told that IHRA have changed their cert and it won't for them. For now you're good for a NHRA cert.
Re: Powder coating chassis [Re: Ted P] #274866
04/06/09 09:13 PM
04/06/09 09:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Isnt it sorta supid that its powder coated and they
(IHRA) wont cert it, all they need to do is scrap the
powder coating off to get the base line then shoot
through the coating from there on, thats all they did
for my painted chassis. I cant imagine the IHRA saying
sorry your chassis is scrap
