Thanks. I really didn't want to drill on my shiny new baseplate though
I heard back from Thumper and he agreed that plugging the dribble hole was the way to go.
So that is what I ended up doing... said to myself that that dribble hole is needed on a vac. sec but not a four corner idle double pumper and I want all the idle mix to be adjustable.
If I need the idle even richer I can always make the air bleeds smaller
It's all back together and on the car. Primary T-slots square, will set the idle with the secondary screw. I notice the secondary T-slots are higher up the bore than the primary, so right now they are not exposed.
Will try it tomorrow maybe, if something's messed up it is a nice afternoon so I quit while I was ahead!
I also drilled the center of the main body 1/4" straight through from the air cleaner stud hole, and drilled/tapped the upper part of the stud mount boss for 5/16.
My plan is to use a brass male (5/16)-to-female (1/4) thread adapter, screw the stud into the adapter, and drill bypass air holes in the adapter if needed, rather than the throttle plates.
Thought about a hollow stud but the walls would be too thin if I need as big an air hole (4 x 3/32 = one 3/16) as I did before.
And I didn't want to drill/tap at angles inside the air horn or near the radiused entrance to the venturis - could affect the flow, and I could imagine a set screw backing out and falling down the intake.
