Re: Help with camshaft
[Re: AndyF]
#2747012
02/27/20 10:56 AM
02/27/20 10:56 AM
Posts: 14,478 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It’s a Comp.
268/271@.050 .440/.436 lobe lift 108lsa
The number at the bottom is the serial #. The “08” at the end is the year it was done.
[Re: fast68plymouth]
#2747394
02/28/20 02:34 PM
02/28/20 02:34 PM
Posts: 16,916 NC
440Jim
NC
It’s a Comp.
The number at the bottom is the serial #. The “08” at the end is the year it was done. Fast68 is the man. From the Comp Cams master list (online) more info on each lobe (int/exh) attached.
