Help with camshaft #2746894
02/26/20 09:59 PM
02/26/20 09:59 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Hi everyone.....can anyone help identify this cam from a BB Mopar....it was in an unlabeled box, and I'm having trouble finding info on it.
Thanks!
Re: Help with camshaft [Re: scarly10] #2746928
02/27/20 12:31 AM
02/27/20 12:31 AM
It really looks like a Comp Cams solid roller lifter cam to me up
Call them and ask them about those numbers as well as the serial number on your cam scope
Re: Help with camshaft [Re: scarly10] #2746933
02/27/20 12:35 AM
02/27/20 12:35 AM
AndyF Offline
AndyF  Offline
Could be Comp Cam. It has a CC mark on there and 4245/4312 would be a decent race cam for a BB Mopar.
Re: Help with camshaft [Re: AndyF] #2747012
02/27/20 10:56 AM
02/27/20 10:56 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It’s a Comp.
268/271@.050
.440/.436 lobe lift
108lsa
The number at the bottom is the serial #.
The “08” at the end is the year it was done.
Re: Help with camshaft [Re: fast68plymouth] #2747141
02/27/20 05:10 PM
02/27/20 05:10 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Thank you!
Re: Help with camshaft [Re: fast68plymouth] #2747394
02/28/20 02:34 PM
02/28/20 02:34 PM
NC
440Jim Online work
440Jim  Online Work
NC
Originally Posted by fast68plymouth
It’s a Comp.
268/271@.050
.440/.436 lobe lift
108lsa
Fast68 is the man. From the Comp Cams master list (online) more info on each lobe (int/exh) attached.
Re: Help with camshaft [Re: 440Jim] #2748136
03/01/20 08:44 PM
03/01/20 08:44 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
$300 if anyone is interested in it
