Re: Proper name for welded bolts ??
[Re: gtx6970]
#2746314
02/25/20 03:25 AM
02/25/20 03:25 AM
Posts: 1,752 Phila
PhillyRag
Phila
Ive always refereed to them as spin weld bolts / studs.
they have a ring or series of raised dots or a ring on the bottom side of the head. The head requires a special fixture to spin the bolt and the ridge or dots weld themselves to the surface due to extreme heat That's Projection Spot Welding. But there is a welding technique that spin welds.
[Re: Stanton]
#2746581
02/26/20 02:08 AM
02/26/20 02:08 AM
Posts: 1,752 Phila
PhillyRag
Phila
I wanted the name so I could see if there were any YouTube videos on how to easily remove them. Studs: grip with a visegrip. Twist slightly in a circular manner. Back-Forth slightly. You should feel the weld "give" (but also maybe base metal). BUT: can't always be certain that base-metal won't "give-way". Of stud has larger dia. & metal thin: isn't tricky. Depends on how "sturdy" the weld is.
