Proper name for welded bolts ?? #2746263
02/24/20 10:35 PM
02/24/20 10:35 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What's the proper name for the miscellaneous studs that are welded to various places - the most common being the pedal bracket in the engine compartment?
Re: Proper name for welded bolts ?? [Re: Stanton] #2746272
02/24/20 11:03 PM
02/24/20 11:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive always refereed to them as spin weld bolts / studs.
they have a ring or series of raised dots or a ring on the bottom side of the head. The head requires a special fixture to spin the bolt and the ridge or dots weld themselves to the surface due to extreme heat
Re: Proper name for welded bolts ?? [Re: gtx6970] #2746314
02/25/20 03:25 AM
02/25/20 03:25 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That's Projection Spot Welding. But there is a welding technique that spin welds.
Re: Proper name for welded bolts ?? [Re: PhillyRag] #2746344
02/25/20 09:47 AM
02/25/20 09:47 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I wanted the name so I could see if there were any YouTube videos on how to easily remove them.
Re: Proper name for welded bolts ?? [Re: Stanton] #2746349
02/25/20 10:13 AM
02/25/20 10:13 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Pem studs, Weld studs, Projection stud...there are a few names and methods for mounting them initially with a quick weld dab to lock em in.
Re: Proper name for welded bolts ?? [Re: Stanton] #2746581
02/26/20 02:08 AM
02/26/20 02:08 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Studs: grip with a visegrip. Twist slightly in a circular manner. Back-Forth slightly. You should feel the weld "give" (but also maybe base metal). BUT: can't always be certain that base-metal won't "give-way". Of stud has larger dia. & metal thin: isn't tricky. Depends on how "sturdy" the weld is.
Carburetor mounting
by 340cpe. 06/02/20 10:07 PM
'69 Charger starting problem
by moparfan53. 06/02/20 09:32 PM
internal alternator parts worth anything?
by Mr T2U. 06/02/20 09:03 PM
Age of Slicks
by 6_pack_runner. 06/02/20 08:35 PM
Moparts Recent Posts
Question on returning leased cars
by not_a_charger. 06/03/20 05:40 AM
Age of Slicks
by dvw. 06/03/20 05:09 AM
How many miles do you drive?
by Dave_J. 06/03/20 04:52 AM
PPP shifter?
by Sammy. 06/03/20 04:15 AM
