Phasing rotor with MSD Crank Trigger #2745846
02/23/20 07:09 PM
02/23/20 07:09 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Total timing advance is 35* locked out.when I drill a hole in the distributor and have my timing mark lined up on crank trigger, my rotor should be on the leading edge of #1 sparkplug.
How close will i be without the car running?
Will it change once i check with the timing light with the car running or should i be good to go?
Re: Phasing rotor with MSD Crank Trigger [Re: Sammy] #2745854
02/23/20 07:49 PM
02/23/20 07:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I use an old cap. Hole in the top of the cap, large enough to see what you're looking at. Look in the hole with the timing light, engine on. Rotor tab should be at the leading edge of the terminal in the cap. Move the distributor to fix the phasing. Move the crank trigger pick up to fix the timing.
Re: Phasing rotor with MSD Crank Trigger [Re: CMcAllister] #2745860
02/23/20 08:16 PM
02/23/20 08:16 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Unless you're running nitrous, or boost, or a ton of start retard where you're pulling a lot of timing, point it dead at the post running, with the timing light.
Re: Phasing rotor with MSD Crank Trigger [Re: Sammy] #2745876
02/23/20 09:03 PM
02/23/20 09:03 PM
AndyF Offline
AndyF  Offline
Put the engine at 35 degrees BTDC on the compression stroke, point the crank trigger sensor at the center of a magnet, point the rotor at #1 tower and then fire it up. Once it is running double check the timing with a timing light and then shine the timing light into the hole in the cap to make sure the rotor is pointed at #1 tower.
Re: Phasing rotor with MSD Crank Trigger [Re: CMcAllister] #2745881
02/23/20 09:24 PM
02/23/20 09:24 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Which leading edge? Towards #8 or #2 edge on the #1 plug. I always forget. Old age.
Re: Phasing rotor with MSD Crank Trigger [Re: Sammy] #2745897
02/23/20 10:34 PM
02/23/20 10:34 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I drilled a 3/8" hole in my dist cap centered under #1 plug wire, painted a white mark on the rotor centered on the electrode. After I have the timing set (engine running) with the crank trigger, I set the rotor phasing, looking into the hole in the dist cap w/ the timing light. I leave the dist cap with the hole in it on the race engine. I have found that it doesn't hurt a thing.
Brian
Re: Phasing rotor with MSD Crank Trigger [Re: Sammy] #2745906
02/23/20 11:17 PM
02/23/20 11:17 PM
AndyF Offline
AndyF  Offline
Don't worry about leading or trailing edges. Just line everything up point to point and then fire it up and check it. That way you'll know what you are looking at. Once you know what you are looking at you can tweak it.
Re: Phasing rotor with MSD Crank Trigger [Re: AndyF] #2745959
02/24/20 01:39 AM
02/24/20 01:39 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
im sure this is the same with th old direct connection crank trigger with the dual plug distributors i have
Re: Phasing rotor with MSD Crank Trigger [Re: dart games] #2745975
02/24/20 05:59 AM
02/24/20 05:59 AM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
This is what I use...check all the “instructions” tab for info
http://www.madcapracing.com/instructions/rotor.shtml
Re: Phasing rotor with MSD Crank Trigger [Re: JMCarter] #2746112
02/24/20 02:54 PM
02/24/20 02:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Didn't work. Try this.
https://www.hotrodhotline.com/conte...hasing-article-msd-ignition#.XlQW0vQkq1s
I assume you are using a distributor with a solid shaft or the advance locked. Using an electronic retard will influence this adjustment.
Re: Phasing rotor with MSD Crank Trigger [Re: CMcAllister] #2746193
02/24/20 07:39 PM
02/24/20 07:39 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I have a start retard.
I'm wondering if 1200 rpms makes a difference to phasing the rotor?
Re: Phasing rotor with MSD Crank Trigger [Re: Sammy] #2746257
02/24/20 10:20 PM
02/24/20 10:20 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not as long as there is no advance function in the distributor.
Re: Phasing rotor with MSD Crank Trigger [Re: CMcAllister] #2746369
02/25/20 11:19 AM
02/25/20 11:19 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I need to phase mine...It's possible to see #1 on the distributor, can I use use any terminal on the distributor as long I clip the timing light on the corresponding plug wire?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Phasing rotor with MSD Crank Trigger [Re: Adobedude] #2746422
02/25/20 01:54 PM
02/25/20 01:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I don't see why not, but #1 is up front at the 5:00 position if it's wired right and should be easy to get to and see through a hole in the top.
Re: Phasing rotor with MSD Crank Trigger [Re: CMcAllister] #2746524
02/25/20 08:11 PM
02/25/20 08:11 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
it doesn't matter where #1 is front, back, left or right. as long as the firing order is right
Re: Phasing rotor with MSD Crank Trigger [Re: plycuda] #2746539
02/25/20 09:13 PM
02/25/20 09:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
True, but my OCD requires me to put them on in the factory configuration, Easy to know what's what without looking. As long as it's factory firing order. Plus, if the pump shaft is in it right, it can only be correct or 180 out.
