Re: Phasing rotor with MSD Crank Trigger
[Re: Sammy]
#2745854
02/23/20 07:49 PM
02/23/20 07:49 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use an old cap. Hole in the top of the cap, large enough to see what you're looking at. Look in the hole with the timing light, engine on. Rotor tab should be at the leading edge of the terminal in the cap. Move the distributor to fix the phasing. Move the crank trigger pick up to fix the timing.
[Re: CMcAllister]
#2745881
02/23/20 09:24 PM
02/23/20 09:24 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I use an old cap. Hole in the top of the cap, large enough to see what you're looking at. Look in the hole with the timing light, engine on. Rotor tab should be at the leading edge of the terminal in the cap. Move the distributor to fix the phasing. Move the crank trigger pick up to fix the timing. Which leading edge? Towards #8 or #2 edge on the #1 plug. I always forget. Old age.
[Re: Sammy]
#2745906
02/23/20 11:17 PM
02/23/20 11:17 PM
Posts: 30,945 Oregon
AndyF
I use an old cap. Hole in the top of the cap, large enough to see what you're looking at. Look in the hole with the timing light, engine on. Rotor tab should be at the leading edge of the terminal in the cap. Move the distributor to fix the phasing. Move the crank trigger pick up to fix the timing. Which leading edge? Towards #8 or #2 edge on the #1 plug. I always forget. Old age. Don't worry about leading or trailing edges. Just line everything up point to point and then fire it up and check it. That way you'll know what you are looking at. Once you know what you are looking at you can tweak it.
[Re: CMcAllister]
#2746193
02/24/20 07:39 PM
02/24/20 07:39 PM
Sammy
Wind Gap,Pa.
I have a start retard. I'm wondering if 1200 rpms makes a difference to phasing the rotor?
[Re: Sammy]
#2746257
02/24/20 10:20 PM
02/24/20 10:20 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have a start retard. I'm wondering if 1200 rpms makes a difference to phasing the rotor? Not as long as there is no advance function in the distributor.
[Re: CMcAllister]
#2746369
02/25/20 11:19 AM
02/25/20 11:19 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I need to phase mine...It's possible to see #1 on the distributor, can I use use any terminal on the distributor as long I clip the timing light on the corresponding plug wire?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2746422
02/25/20 01:54 PM
02/25/20 01:54 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I need to phase mine...It's possible to see #1 on the distributor, can I use use any terminal on the distributor as long I clip the timing light on the corresponding plug wire? I don't see why not, but #1 is up front at the 5:00 position if it's wired right and should be easy to get to and see through a hole in the top.
[Re: CMcAllister]
#2746524
02/25/20 08:11 PM
02/25/20 08:11 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
I need to phase mine...It's possible to see #1 on the distributor, can I use use any terminal on the distributor as long I clip the timing light on the corresponding plug wire? I don't see why not, but #1 is up front at the 5:00 position if it's wired right and should be easy to get to and see through a hole in the top. it doesn't matter where #1 is front, back, left or right. as long as the firing order is right
[Re: plycuda]
#2746539
02/25/20 09:13 PM
02/25/20 09:13 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
True, but my OCD requires me to put them on in the factory configuration, Easy to know what's what without looking. As long as it's factory firing order. Plus, if the pump shaft is in it right, it can only be correct or 180 out.
