Putting this 451 B engine into a '74 duster. Got the TTI's for the big block swap.And the Schumacher mounts. Right side header is close to the inner fender but will be OK...left side header is up against the steering coupler. We converted this car from power to manual steering using the Mancini adaptor to the box. If the original coupler wasn't there, we'd have clearance at the tube. Aside from trying to find a manual steering column shaft for one of these cars, what else will fit?? Any other body styles? B Body???...E body???... if so what years. I could I suppose get and early A body column but then the ignition isn't on the column. HELP !!
