Heat Riser Kit #2745789
02/23/20 03:45 PM
02/23/20 03:45 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi, I was wondering if anyone ever used the Heat Riser Kit to rebuild their own? Was there any difficulty? Or does anyone have any other suggestions on how to fix a leak at the heat riser? I know there are bushing, but do the exhaust manifolds have to be taken off to be drilled?
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Heat Riser Kit [Re: GTXKARL] #2745796
02/23/20 04:17 PM
02/23/20 04:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes the manifold needs to come off. Not to hard to do.
Re: Heat Riser Kit [Re: NITROUSN] #2745797
02/23/20 04:18 PM
02/23/20 04:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What intake manifold do you have? If the crossover is not used you could remove the heat riser and plug the shaft holes in the manifold.
Re: Heat Riser Kit [Re: NITROUSN] #2745871
02/23/20 08:50 PM
02/23/20 08:50 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
44o six pack intake.
Re: Heat Riser Kit [Re: GTXKARL] #2745883
02/23/20 09:29 PM
02/23/20 09:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most likely you would be better off to rebuild the heat riser as I assume you have the stock automatic choke.
Re: Heat Riser Kit [Re: GTXKARL] #2746219
02/24/20 08:49 PM
02/24/20 08:49 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Need Detailed Instructions on How to Install. heat riser 1970 plymouth gtx 440 eng
Re: Heat Riser Kit [Re: GTXKARL] #2746245
02/24/20 09:56 PM
02/24/20 09:56 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This should give you an idea. You should consider a FSM.
Re: Heat Riser Kit [Re: NITROUSN] #2746500
02/25/20 06:43 PM
02/25/20 06:43 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Thank you for your help! Just what I was looking for. Maybe your right. I may need a factory service manual.
