Head gasket on aluminum block #2745362
02/22/20 01:07 AM
02/22/20 01:07 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Cylinder liners currently have O-ring grooves. Grooves are about .038" wide.
Between the grooves at their closest point, between the bores, is only about .030".
So at that same point, it is about .105" from groove inner ID - to - inner ID., .038 + .030 + .038 = .106
1.) Which head gasket should I use ?
2.) The liners stick up a few thou above the deck. Is this OK with a conventional gasket ? Cometic told me No, with theirs.
3.) Should I just fill in the grooves flush to the top of the liner ?
Re: Head gasket on aluminum block [Re: hemienvy] #2745370
02/22/20 01:55 AM
02/22/20 01:55 AM
Call SCE gasket company at 661-728-9200(they've been bought and moved several times in ten last 5 yrs whiney) and get help on getting the correct copper head gaskest for your motor up
I've used a bunch of their copper head gaskets on several blown as well as N/A Hemi and other BB Mopar with no failures up
Re: Head gasket on aluminum block [Re: Cab_Burge] #2746012
02/24/20 09:46 AM
02/24/20 09:46 AM
an8sec70cuda Offline
iagree I'm not a fan of copper gaskets, but I'd just deal w/ it and use them in your case. I used them on our 436" SB chevy and have no issues.
CHIP
'06 GMC 2500HD LBZ Duramax
