Re: Comp height on 68-70 383 pistons
[Re: lewtot184]
#2745633
02/22/20 09:15 PM
02/22/20 09:15 PM
Posts: 104 Minnesota
TrackPack
Minnesota
So, 2315's in a 4.290 bore sounds like the best solution without blowing the budget. As mentioned, these pistons came out as a forged replacement for stock pistons, so balancing wasn't an issue supposedly. Be nice to find a set of heads without the huge combustion chamber, but that can be changed in the future. Good luck and hope it all works out.
[Re: lewtot184]
#2745643
02/22/20 09:59 PM
02/22/20 09:59 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
i'm going to take a stab at piston/pin weights. a 2315 will be very close to 1000grms. a stock is around 1000grms. kb162 about 930grms. the last 383 I did had 8:1 cast in it and they were replaced with 2315's. I don't know the weight of those 8:1 pistons. we didn't re-balance, which I would have preferred, but there absolutely was no money so it went together. I was dumbfounded by how smooth the engine ran. actually noticeably smoother than my balanced "properly put together" 440. This. The 2315 and the factory pistons were the same within their respective tolerances, probably +/- 10 grams. The 2315 comes with a factory-like pin as well, total right at Lew's 1000 gr.
[Re: BSB67]
#2745649
02/22/20 10:29 PM
02/22/20 10:29 PM
Posts: 3,916 usa
lewtot184
usa
i'm going to take a stab at piston/pin weights. a 2315 will be very close to 1000grms. a stock is around 1000grms. kb162 about 930grms. the last 383 I did had 8:1 cast in it and they were replaced with 2315's. I don't know the weight of those 8:1 pistons. we didn't re-balance, which I would have preferred, but there absolutely was no money so it went together. I was dumbfounded by how smooth the engine ran. actually noticeably smoother than my balanced "properly put together" 440. This. The 2315 and the factory pistons were the same within their respective tolerances, probably +/- 10 grams. The 2315 comes with a factory-like pin as well, total right at Lew's 1000 gr. factory piston is 770grms. .040" 2315 will be close to 790. I wasn't trying to get the OP to spend $400 on new pistons. balancing for the kb162's is cheaper. it's my understanding balancing is not an exact science. I was just trying to layout some differences and how some perceptions fool us. either way it will work.
[Re: lewtot184]
#2745669
02/23/20 02:23 AM
02/23/20 02:23 AM
Posts: 43,882 Bend,OR USA
Cab_Burge
Mopar made some embellished "factory blue print" information to NHRA back in the late 1960s and early 1970s, the 1970 383 motors being one of them, No stock 1970 383 motors made had anywhere close to +.005 piston tops above the decks, none of them The standard stamp steel head gaskets for the 361,383 413 and all of the 426W where all .022 thick I use to keep dozens of them in stock until you couldn't buy them anymore Ford said that the 1968 428 Cobra Jet motors had 335 HP, just like the 1966 and 1967 390 HP had Hence the Mopar response in 1969 for the 1970 model year
[Re: Cab_Burge]
#2745896
02/23/20 09:31 PM
02/23/20 09:31 PM
Posts: 6,620 Abilene, Texas
fastmark
Abilene, Texas
We can’t use the kB now. We’re getting the 2315f. I just have to figure out the heads. Now that I think about it, I have a original 70 383 hp short block at the shop. I’ll measure the C.H. of a piston.
[Re: fastmark]
#2745954
02/24/20 12:27 AM
02/24/20 12:27 AM
Cab_Burge
Do you mean deck height of thosestock pistons?
[Re: Cab_Burge]
#2745986
02/24/20 07:27 AM
02/24/20 07:27 AM
fastmark
Abilene, Texas
Do you mean deck height of thosestock pistons? I can measure the compression height and figure out what the deck height would be. I could install it but it’s a std bore piston in a .030 hole. I don’t know if I can get the old motor to turn over easily.
[Re: fastmark]
#2746028
02/24/20 09:38 AM
02/24/20 09:38 AM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d just forge ahead on repairing the current motor, instead of starting all over again.
If nothing else...... the heads should be good cores with new parts.
It really shouldn’t be that expensive to fix them up.
[Re: lewtot184]
#2746223
02/24/20 08:05 PM
02/24/20 08:05 PM
Posts: 2,821 Sobieski Wi
bee1971
Sobieski Wi
Using the stock block height spec of 9.98 along with a piston ch of 1.920(L2315F, no valve pockets),at .030 over, .040 gasket, 84cc heads........ I get 9.14:1.
797- swept 84- chamber 2.8 - deck 10- gasket 1- area above rings ————- 894.8 total 97.8 total minus swept ————- 9.14:1
Imo, that’s the easy button for a street 383. Deck block for zero deck gets you to 9.38:1. Swap to 78cc closed chamber heads and you’re at 9.95:1 with good quench.
A 1.908ch piston should be sitting .024” down the hole of an uncut block. The 1.848ch piston would be down the hole .084”.
With the 1.848ch pistons (no dish, no valve pocket) at + .030 and 90cc heads with a shim gasket:
797- swept 90- chamber 19.8- deck 5- shim gasket 1- area above rings ————- 912.8- total 115.8 - total minus swept ————- 7.88:1
Mill the heads to 84cc and you’re at 8.25:1. the 383 I did a few years back with .030 over 2315 pistons and '906 heads (with .015" off them) was around 9.24:1 with a .039" head gasket. the 2315 piston is an easy no brainer. I ran the 2315 pistons .030 over - 906 heads - Mopar 284/484 cam - For 20 years in my numbers block with zero issues Then I got greedy , and installed the E Street 75cc heads on that same setup a few years back Looking for more Motor ran awesome , 6,000 Rpms came on really really fast on the highway running 3:91 gears if you weren’t paying attention Right up until I kissed two intake valves , took out the pushrods , lifters , and camshaft - Again greedy Then I decided to build my 432 Stroker So watch your camshaft selection and valve clearance - Only disadvantage , no valve reliefs
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2746260
02/24/20 09:24 PM
02/24/20 09:24 PM
Posts: 3,916 usa
lewtot184
usa
Mill the heads to 84cc and you’re at 8.25:1. the 383 I did a few years back with .030 over 2315 pistons and '906 heads (with .015" off them) was around 9.24:1 with a .039" head gasket. the 2315 piston is an easy no brainer. I ran the 2315 pistons .030 over - 906 heads - Mopar 284/484 cam - For 20 years in my numbers block with zero issues Then I got greedy , and installed the E Street 75cc heads on that same setup a few years back Looking for more Motor ran awesome , 6,000 Rpms came on really really fast on the highway running 3:91 gears if you weren’t paying attention Right up until I kissed two intake valves , took out the pushrods , lifters , and camshaft - Again greedy Then I decided to build my 432 Stroker So watch your camshaft selection and valve clearance - Only disadvantage , no valve reliefs performance 383's need valve reliefs in the pistons. I've busted a lot of parts with flat tops, no reliefs, 4spd and 383.
[Re: lewtot184]
#2746284
02/24/20 10:30 PM
02/24/20 10:30 PM
Posts: 208 PA
Scully
PA
I've built plenty of budget street .070" 383s using these or similar for my customers, the deck height is almost identical to the 68-69 383. At one time I had a barrel full of stock standard 72 440 style pistons and found a good use for them. https://www.summitracing.com/parts/slp-424np?rrec=true a .040" over makes a budget .020" 400.
[Re: fastmark]
#2746380
02/25/20 11:08 AM
02/25/20 11:08 AM
fast68plymouth
So. Burlington, Vt.
FWIW, I don’t pay any attention at all to what the factory CR specs are. Pretty much useless info for the real world.
Measure everything...... and iiwii, regardless of what any spec in any book says.
And yes......... it’s easy to spend Stealth money on fixing old heads...... even refurbished ones, if they’re screwed up enough.
[Re: lewtot184]
#2746658
02/26/20 10:56 AM
02/26/20 10:56 AM
Posts: 8,816 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
the difference in compression ratios were different chambers and 2bbl vs 4bbl pistons. using stock hydraulic cam valvetrains may be the biggest culprits to piston to valve collision. when the springs would float the tappets would pump up (keep in mind .100+" pre-load on the tappets) and the intake valve is into the piston. tight lobe separations, added duration, aggressive lobes, increased lift just makes matters worse. keep in mind that the intake valve is chasing the piston on it's downward motion and the valve is moving faster than the piston. valve reliefs are the only true answer to the problem. a stock magnum cam with slower ramps and wider lobe separation is safer but like all hydraulics needs pre-load reduced. aftermarket rockers usually have higher than advertised ratios so using them may not be the cure.
the 2315's are easy to use but can set you up for piston to valve collision when revving the engine up. the kb162 is safer and lighter. another thing; big valves will give you a little less piston to valve clearance. advancing the cam will reduce clearance, AND, don't over cam a 383. Zero valve lash and triple springs, no valve float or kissed pistons, shifted my 383 @6800 all day long, MP 509
[Re: cudaman1969]
#2746680
02/26/20 12:00 PM
02/26/20 12:00 PM
fast68plymouth
So. Burlington, Vt.
I really don’t think V/P clearance will be an issue at all for the proposed build if an “appropriately” sized cam is used, and the heads/block are not excessively milled.
2315’s with the heads/block/gasket situation set up for low 9’s CR shouldn’t present any problems with a suitable street cam.
The stock eliminator guys get it done without valve pockets(pistons have to be stock configuration) and much bigger cams than what this build will get.
[Re: fast68plymouth]
#2746725
02/26/20 01:29 PM
02/26/20 01:29 PM
Posts: 3,916 usa
lewtot184
usa
The stock eliminator guys get it done without valve pockets(pistons have to be stock configuration) and much bigger cams than what this build will get. stocker guys don't run .100" preload on their tappets. ain't apples to apples.
