Radiator trans lines fitting? #2745045
02/20/20 08:36 PM
02/20/20 08:36 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Can anyone tell me what the factory fitting thread sizes are for the radiator to trans lines fittings? 1/4NPT to 5/16 compression?
Chris
Re: Radiator trans lines fitting? [Re: cdp] #2745096
02/21/20 12:55 AM
02/21/20 12:55 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
1/8 npt x 5/16 tube flare
Re: Radiator trans lines fitting? [Re: calrobb2000] #2745182
02/21/20 12:14 PM
02/21/20 12:14 PM
moparx Offline
moparx  Offline
i believe the transmission end fitting is 1/8NPT, while the radiator end is 1/4NPT.
line size is 5/16 with tube nuts.
beer
Re: Radiator trans lines fitting? [Re: moparx] #2745235
02/21/20 02:43 PM
02/21/20 02:43 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
All 4 NPT fittings are the same...Pretty sure they are 1/8" NPT...
...FAFO...
Re: Radiator trans lines fitting? [Re: skicker] #2746054
02/24/20 11:57 AM
02/24/20 11:57 AM
moparx Offline
moparx  Offline
you, sir are correct ! up
i had reason to remove a couple of radiator nipples yesterday, and 1/8"NPT they were !
thanks for setting the record straight.
now, if i can only remember.......... biggrin
beer
