1988 D50 pickup #2745057
02/20/20 09:48 PM
02/20/20 09:48 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Has anyone ever put a small block or gen III Hemi in one for the street? Got one from my deceased brother in law and just thinking out loud
Re: 1988 D50 pickup [Re: cudaman1969] #2745063
02/20/20 09:59 PM
02/20/20 09:59 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Dont have that answer but I know the complete head and turbo from a Eclipse/Talon will bolt on some of them. With mods 400 HP is doable.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 1988 D50 pickup [Re: cudaman1969] #2745069
02/20/20 10:20 PM
02/20/20 10:20 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
No personal experience but the ones with an auto trans are supposed to be the easiest because they used a 904. Swing in a small block with trans, line up the trans mount and let the front land where it lands. Fab mounts to suit or motor plate.
Kevin
Re: 1988 D50 pickup [Re: cudaman1969] #2745070
02/20/20 10:27 PM
02/20/20 10:27 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I had one with a 2.0 liter with a 2.6 conquest turbo top end. My friend and I put a Buick GN drivetrain in another one also. The V6 truck ended up with the radiator mounted in the bed. The factory rear axle held up to low 11second E.T.s
Re: 1988 D50 pickup [Re: cudaman1969] #2745079
02/20/20 11:04 PM
02/20/20 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put a SB LA 418 in my my Dodge Rampage ... it WILL fit
wave
Re: 1988 D50 pickup [Re: MR_P_BODY] #2745088
02/21/20 12:14 AM
02/21/20 12:14 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've seen one with a SB in it, fit nicer than an RB in a Duster.
Those trucks are light, too.
Re: 1988 D50 pickup [Re: MR_P_BODY] #2745098
02/21/20 01:03 AM
02/21/20 01:03 AM
fredericksburg,va
fredericksburg,va
wave
That IS nice
Re: 1988 D50 pickup [Re: cudaman1969] #2745099
02/21/20 01:08 AM
02/21/20 01:08 AM
fredericksburg,va
fredericksburg,va
Since it’s an extended cab I could move the firewall back some. It’s a 4x4 but all that can be changed out. I’m thinking the overdrive 904 unit and a turbo 5.7 hemi, I have the nag trans too but would need controller for both. Oh yea, body-frame is perfect
Re: 1988 D50 pickup [Re: Dave_J] #2745101
02/21/20 01:11 AM
02/21/20 01:11 AM
fredericksburg,va
fredericksburg,va
What years for that head-turbo
Re: 1988 D50 pickup [Re: cudaman1969] #2745114
02/21/20 03:11 AM
02/21/20 03:11 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Buddy of mine is looking for a D-50 to do a Gen 3 swap in. Apparently it's a fairly common swap.
There's one that races around here with an RB in it. Not sure how much he cut out to get it there.
Re: 1988 D50 pickup [Re: cudaman1969] #2745148
02/21/20 10:50 AM
02/21/20 10:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks.. I set it up with a 518OD and fuel injected
wave
Re: 1988 D50 pickup [Re: cudaman1969] #2745164
02/21/20 11:22 AM
02/21/20 11:22 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
I had one of those and daydreamed about putting a small block in. I took some measurements and IIRC it would fit but there might be some reconfiguration needed of course. Mine was a 2wd.
A local guy had one of the prior gen trucks with a 440 in it, but the firewall had been cut.
Not mine
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: 1988 D50 pickup [Re: Bob Stinson] #2745239
02/21/20 02:51 PM
02/21/20 02:51 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I put a 340 in a 79-86 body style back in the late 80's...I've never messed with the newer body style...
Mine was a 79 D-50 Sport...I'd do it again if I can find the right truck...
...FAFO...
Re: 1988 D50 pickup [Re: skicker] #2745301
02/21/20 08:26 PM
02/21/20 08:26 PM
fredericksburg,va
fredericksburg,va
Did you use the body style like above or the first “Dodge” pickup?
I checked and we’re talking same model. Can you walk me through how or what you did to install the 340? Any weird things like oil pan, fan or radiator, exhaust route
Re: 1988 D50 pickup [Re: cudaman1969] #2745311
02/21/20 09:09 PM
02/21/20 09:09 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
This is what mine looked like...
Before and after...
Attached PDF document
img-620073129-0001.pdf (49 downloads)
...FAFO...
