Re: W200 horn ring - missing parts
[Re: General 68]
#2744832
02/20/20 05:01 AM
02/20/20 05:01 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
How about a pic of what you have, different years may be the same.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: NITROUSN]
#2744963
02/20/20 03:20 PM
02/20/20 03:20 PM
Posts: 401 Norway
General 68
Norway
Thanks Nitrousn😀 I'll dig into it. Here is all the parts I have. Looks like I am missing the isolator spacer. Everything here now grounds.
[Re: NITROUSN]
#2744977
02/20/20 03:57 PM
02/20/20 03:57 PM
Posts: 401 Norway
General 68
Norway
Here is a pic after pullig the thing apart.
[Re: General 68]
#2745042
02/20/20 08:27 PM
02/20/20 08:27 PM
Guitar Jones
Found this pic at Allpar. The three black plastic pieces seems to be what is missing. What is inside them? Springs? Yes, mine has springs in it.
[Re: General 68]
#2745144
02/21/20 10:39 AM
02/21/20 10:39 AM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Thanks! Seems like the isolators/fasteeners are missing then. I wonder how they look like other than from top view. Someone has definetly done some work in there😂 You have nothing missing just a switch that is been taken apart and improperly put back together. Basically junk. I think someone found a switch and was trying to adapt the wheel center cap to fit it. The standard column only had the switch and 3 screws to bolt it directly to the wheel. The isolation was built into the switch. On a tilt column you had a wave type spring washer that went against the wheel then the switch, then a plastic 3 eared insulator, and then 3 shouldered screws. I will post a 1980 standard wheel with a horn switch for a round center cap. I would give it to you and your horn will work, but your center cap wont fit.
[Re: NITROUSN]
#2745238
02/21/20 02:50 PM
02/21/20 02:50 PM
NITROUSN
Here are 2 more pictures of what you need. You can see the 3 screws that go through the switch into the horn pad adapter. You would take this switch part number 2771534 and attach your horn pad ring to it. Then you would screw it down through the 3 other holes to the steering wheel. The horn pad adapter is different than yours as seem by the photo. Just google the part number and get your part.
