Dealer replaced Hemis
#2744686
02/19/20 06:37 PM
02/19/20 06:37 PM
Posts: 1,548 Michigan
Kiddart
what happens to all or some of the Motors that a dealership pulls as warranty and puts new motors in? I would like to get my hands on one or two. as long there isn't a hole in the block.
Thank you Kiddart
Re: Dealer replaced Hemis
[Re: Kiddart]
#2744777
02/19/20 10:10 PM
02/19/20 10:10 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
They send em back to the factory to be re-built for the next warranty replacement job. Usually a pretty steep core charge for customer pay replacement engines so those will be hard to justify either.
[Re: HotRodDave]
#2744999
02/20/20 05:04 PM
02/20/20 05:04 PM
Kiddart
I figured, never an easy way or at least a easy path
Thank you Kiddart
[Re: Kiddart]
#2745030
02/20/20 07:33 PM
02/20/20 07:33 PM
HotRodDave
Kalispell Mt.
something in particular your looking for?
[Re: HotRodDave]
#2745161
02/21/20 11:11 AM
02/21/20 11:11 AM
Kiddart
I am looking for a 6.1 or a 6.4 on the cheap and I mean real cheap. I have a 5.7 now runs good fun to drive but as always want to upsize just a little. I also have a spare 5.7 in pieces that I can do just about anything I want with. But I do want to keep the motor in my car in tact as a spare on the stand in the garage. I think I should just go with my gut and do the rod and piston change to the one in pieces, find another set of eagle heads and stop trying to be so cheap.
Thoughts?
Thank you Kiddart
[Re: Kiddart]
#2745236
02/21/20 02:46 PM
02/21/20 02:46 PM
Posts: 2,255 IL
furious70
IL
how cheap is cheap? There are running BGE's on ebay for $3500-4500, just need the SRT cam in it.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2745246
02/21/20 03:53 PM
02/21/20 03:53 PM
HotRodDave
Kalispell Mt.
I have a 90,000 mile BGE oil pan to valve covers (no intake or I can throw in an eagle intake) for $2500 if you know how to get it shipped to you.
[Re: HotRodDave]
#2745728
02/23/20 11:54 AM
02/23/20 11:54 AM
Kiddart
cheap to me is $500 or better.
Thank you Kiddart
[Re: Kiddart]
#2745740
02/23/20 12:14 PM
02/23/20 12:14 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
cheap to me is $500 or better. That’s not worth the paperwork (and LIABILITY) for FCA to hassle with. Not even close. They are sent to the crusher.
[Re: SRT6776]
#2746137
02/24/20 03:57 PM
02/24/20 03:57 PM
HotRodDave
Kalispell Mt.
I could hook a guy up with all the basic hard parts to build an early 5.7 longblock for $500 butt the block needs bored and new pistons. If you wanted an eagle 5.7 I could do that for $500 and decent used pistons and block that could be used for a budget build without even a bore. Again you would have to finger out how to ship it to where ever you are.
