8 3/4 to a Dana #2744472
02/19/20 01:51 AM
02/19/20 01:51 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
I am going to order up a Dana 60 for the Scamp I am assuming will need to get a new drive shaft?
Info appreciated
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 8 3/4 to a Dana [Re: Stroker Scamp] #2744474
02/19/20 02:13 AM
02/19/20 02:13 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Info appreciated
When I did the swap had to get the shaft shortened, get the 60 installed & see if the old shaft fits, if not measure & get it fixed.
Re: 8 3/4 to a Dana [Re: Stroker Scamp] #2744494
02/19/20 08:21 AM
02/19/20 08:21 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Info appreciated
If rear ends are installed in the same location your drive shaft will have to be shorten.
Re: 8 3/4 to a Dana [Re: DusterKid] #2744505
02/19/20 09:09 AM
02/19/20 09:09 AM
an8sec70cuda Offline
Info appreciated
iagree Somewhere around an inch if I recall correctly.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 to a Dana [Re: Stroker Scamp] #2744514
02/19/20 09:41 AM
02/19/20 09:41 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Is the pinion stem at the same vertical height?
The Ford 9" is lower, affects the angle.
Boffin Emeritus
Re: 8 3/4 to a Dana [Re: polyspheric] #2744524
02/19/20 10:16 AM
02/19/20 10:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Good time to think about saving some weight.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 8 3/4 to a Dana [Re: hemi-itis] #2744527
02/19/20 10:19 AM
02/19/20 10:19 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes it will weigh more but it will not slow your car down because of the increased efficiency.
Re: 8 3/4 to a Dana [Re: 340Cuda] #2744596
02/19/20 01:10 PM
02/19/20 01:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IIRC a test was run with an 8-3/4 vs. 60, and the ET was really close. The extra efficiency almost exactly made up for the extra 75 lb. weight gain.
IDR anything easy that saves weight on the Dana, though. Smaller brakes?
Boffin Emeritus
Re: 8 3/4 to a Dana [Re: polyspheric] #2744603
02/19/20 01:28 PM
02/19/20 01:28 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Although I don't have the weights in front of me, going with a spool should be worth something.
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 8 3/4 to a Dana [Re: an8sec70cuda] #2744621
02/19/20 02:26 PM
02/19/20 02:26 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Quote
1 1/8" to be exact
Centerline of Axle Shaft to
Center of Universal Yoke
8 3/4" 12.35"
9 3/4" 13.47"
Re: 8 3/4 to a Dana [Re: John_Kunkel] #2744850
02/20/20 08:53 AM
02/20/20 08:53 AM
Going from a locker/suregrip to a spool in a Dana is worth something like 20 lbs. Might be more than that actually.
CHIP
Re: 8 3/4 to a Dana [Re: an8sec70cuda] #2745361
02/22/20 01:05 AM
02/22/20 01:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All else being equal, a 35 spline S-60 with a traction differential is 50 lbs heavier than a 30 spline 8 3/4" with a traction differential.
Re: 8 3/4 to a Dana [Re: DoctorDiff] #2745427
02/22/20 10:33 AM
02/22/20 10:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The weight that was lifted from my shoulders on my S60 over the 8.75 that was in the car was much higher than 50lb! laugh2
Set it.... and forget it!
