What oil to use #2744562
02/19/20 11:53 AM
02/19/20 11:53 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
What oil are you.running when running methanol Engine oil WT and brand
Re: What oil to use [Re: dragon] #2744563
02/19/20 11:58 AM
02/19/20 11:58 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We use NOTHING but Lucas. Tried a few other brands and for us Lucas 50w racing is by far the best. I'd pay for it before using anything else for free.
Re: What oil to use [Re: dragon] #2744594
02/19/20 01:07 PM
02/19/20 01:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Klotz Uplon in the fuel
Boffin Emeritus
Re: What oil to use [Re: dragon] #2744973
02/20/20 03:46 PM
02/20/20 03:46 PM
gregsdart Offline
gregsdart  Offline
VR1 20w50 racing. Methanol injected.
Re: What oil to use [Re: gregsdart] #2744998
02/20/20 05:03 PM
02/20/20 05:03 PM
Louisiana
BiomedTechGuy Offline
Louisiana
No methanol, but since another forum member uses it, I'll add that I have been using Valvoline VR1 for my flat tappet hydraulic lifter equipped 440, and I was using it in our Pontiac Tripower 421 GTO, until it was rebuilt with CompCams hydraulic roller lifters.
I replaced the lifters and springs in my 440 because they needed it. I don't know how old they were or what they had "been through" when I bought my 440 6bbl equipped V-code 70 Roadrunner, but they needed replacement. The new lifters and springs brought out the full performance of the 292°/.509 Purple Stripe cam, and that turned the 440 into a force to be reckoned with, as it should be.
I did use moly assembly lube and Lucas break in additive when I installed the new lifters with the existing cam notated, and broke in the combo like a new cam and FT lifters would be, and have had nothing but great results. That has been about 4 years ago, and is the best improvement so far out of everything I've done.
