Re: Junkyard 5.7 check?
[Re: tdmoparguy]
#2743946
02/17/20 01:24 PM
02/17/20 01:24 PM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
there is more than 4 bolts butt yes it is very easy to pull the intake and with the awesome port configuration you can see the entire back of the valve. If your taking a chance on an un-known like a pull apart engine get one from the car, the Durangos have a cowling that dumps rain water on the top of the engine, when the intake gaskets get worn out (flatened) that water can run into an intake port and the engine will hydrolock on start up and break rods, sometimes they come out the side of the block, sometimes you can just throw a new rod in and move on with life.
[Re: HotRodDave]
#2744058
02/17/20 08:49 PM
02/17/20 08:49 PM
Posts: 1,396 Central Pa
moparjim79
Central Pa
there is more than 4 bolts butt yes it is very easy to pull the intake and with the awesome port configuration you can see the entire back of the valve. If your taking a chance on an un-known like a pull apart engine get one from the car, the Durangos have a cowling that dumps rain water on the top of the engine, when the intake gaskets get worn out (flatened) that water can run into an intake port and the engine will hydrolock on start up and break rods, sometimes they come out the side of the block, sometimes you can just throw a new rod in and move on with life. I simply meant instead of pulling the 4 bolts which hold the throttle body, pull the 8 intake bolts (or maybe there is 10). OP-best of luck man
