Yes just bought a set. They didn't have any shafts back from the hard chromers. So I bought the rocker arms and used Hughes shafts. They only make them in 1.6 ratio.
The RAS shafts I purchased in the past are much beefier than the multiple sets of Hughes shafts I own(ed). But they're priced accordingly to go with the extra strength and additional oiling mods.
Depending upon the application, the Hughes shafts are perfectly usable. And, if I was still using heads that worked with standard-offset intake rockers, I'd be kicking myself for having solid my set of rockers & shafts years ago.
The only drawback, as pointed out, is they are very nose heavy as a result of their "built like a bridge support" design.
