511 winter updates #2743553
02/16/20 01:42 PM
02/16/20 01:42 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Been tinkering in the garage on these cold boring weekends. Yesterday decided to clean up my Indy 400-3 because I thought it could use it and had nothing else to do. It was getting a bit dirty, so gave it a few coats of plasticolor with ceramic engine part.
Re: 511 winter updates [Re: mopar dave] #2743554
02/16/20 01:44 PM
02/16/20 01:44 PM
Mt Morris Michigan
Mt Morris Michigan
Few more.
Re: 511 winter updates [Re: mopar dave] #2743555
02/16/20 01:46 PM
02/16/20 01:46 PM
Mt Morris Michigan
Mt Morris Michigan
Getting closer.
Re: 511 winter updates [Re: mopar dave] #2743558
02/16/20 01:48 PM
02/16/20 01:48 PM
Mt Morris Michigan
Mt Morris Michigan
Have a new cooling fan system with much bigger fans. Hope it cools this time, if not I will go back to mechanical fan and pump for good.
Re: 511 winter updates [Re: mopar dave] #2743564
02/16/20 02:04 PM
02/16/20 02:04 PM
Texas
RustyM Offline
RustyM  Offline
Texas
all looks great Dave.
I cut in rectangles in our fan shrouds and attack rubber flaps that open with mph but are pulled shut with the fan- seems to have helped a bit but, wont no for sure till we get in the upper 90's and above.
Re: 511 winter updates [Re: RustyM] #2743583
02/16/20 02:35 PM
02/16/20 02:35 PM
Mt Morris Michigan
Mt Morris Michigan
That's what my other fan shroud had, but smaller fans as well. I couldn't get it to cool in hot weather cruising down the road at any speed(218*). When I stopped it would cool down to the 200* range + or minus. Seemed like it wasn't getting enough air flow at speed.I drilled more 1" holes and added more rubber flaps to no avail. Couldn't figure it out, so back on went the mechanical fan. Cooled just fine. These Spal fans are the paddle variety and move much more air. Will see, fingers crossed.
Re: 511 winter updates [Re: mopar dave] #2743623
02/16/20 03:50 PM
02/16/20 03:50 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
that shroud is a killer we had customers who couldn't get their cars cooling with that fan setup. the shroud is a crappy design and block a lot of air flow
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 511 winter updates [Re: Jerry] #2743646
02/16/20 04:28 PM
02/16/20 04:28 PM
Mt Morris Michigan
Mt Morris Michigan
After using the other style with the 1” holes and rubber flaps I think it really comes down to fans and biggest most powerful fans that with fit. If the fans move enough air there should be no issue with air flow, at least that’s my idea. Like said earlier, if this set up doesn’t work I’m done spending money on it. Flex fan with Milodon hp pump and a shroud over cools this 511 filled with hard block.
Re: 511 winter updates [Re: mopar dave] #2743673
02/16/20 05:47 PM
02/16/20 05:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The intake mods alone should be worth a tenth at least. ...Very nice. I ended up with an open space gave e the best ET....Mine want more plenum.
Also, if she is running hot, I went to a flow kooler mechanical, and that is working awesome....Might actually go back to mechanical on my Hemi...
Re: 511 winter updates [Re: Dragula] #2743723
02/16/20 08:09 PM
02/16/20 08:09 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Think you are on the right track
Bet the fans help a bunch
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 511 winter updates [Re: B3422W5] #2743733
02/16/20 08:29 PM
02/16/20 08:29 PM
Dragula Offline
Dragula  Offline
We sit around sometimes down at the shop and think about what is left on the table, and porting an intake like you did is numero uno......
Re: 511 winter updates [Re: Dragula] #2743741
02/16/20 08:52 PM
02/16/20 08:52 PM
Mt Morris Michigan
Mt Morris Michigan
Last summer I removed the cast in clover leaf and opened up the plenum a bit. It was a bit of a hack job, so yesterday just wanted to clean that up and blend/ contour the plenum to the runners. As for the runners, I just took off the rough casting, just smoothing it out. I left the floor alone because I understand air/fuel moves thru the center of the port following close to the roof. Hope your right.
Re: 511 winter updates [Re: Dragula] #2743895
02/17/20 11:44 AM
02/17/20 11:44 AM
Mt Morris Michigan
Mt Morris Michigan
Dracula, what electric fan/shroud did you try that didn’t work out for you?
Re: 511 winter updates [Re: mopar dave] #2743911
02/17/20 12:21 PM
02/17/20 12:21 PM
UK
rb446 Offline
rb446  Offline
UK
We got something similar, hope this works ok, cars gonna see some street driving as well>
https://ibb.co/cy9DpK7][Linked Image][/url]
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 511 winter updates [Re: mopar dave] #2743927
02/17/20 12:51 PM
02/17/20 12:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can't go wrong w/the HHR fan deal and it keeps my junk cool even in 100+ degree weather......
Re: 511 winter updates [Re: rb446] #2743932
02/17/20 01:02 PM
02/17/20 01:02 PM
Mt Morris Michigan
Mt Morris Michigan
I don’t think your gonna get enough air flow on the street. You’ll have to try. I have my other shroud fan kit for sale in the classifieds. Your fans look the same.
Re: 511 winter updates [Re: mopar dave] #2744031
02/17/20 08:08 PM
02/17/20 08:08 PM
Dragula Offline
Dragula  Offline
Well that big iron block is really tough to cool on the street on a 90* day....At the track its not an issue at all, but cooling 300lbs of cast iron is a beotch on the street. I went to these fans, and they did help.
https://www.summitracing.com/parts/bci-75638
