Dash Frame Rotisserie/Holder #2743511
02/16/20 11:50 AM
02/16/20 11:50 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Does anyone sell or make a dash frame rotisserie/holder? One that you could bolt the dash frame into and then assemble the dash prior to installation in the car? Thanks !
Re: Dash Frame Rotisserie/Holder [Re: 44D6PAKCUDA] #2743529
02/16/20 12:33 PM
02/16/20 12:33 PM
MD
floyd Offline
floyd  Offline
MD
Here are some posts with homemade remedies:
https://board.moparts.org/ubbthread...e-dash-frame-holder-built-from-2x4s.html
http://www.dodgecharger.com/forum/index.php/topic,18259.0.html
Re: Dash Frame Rotisserie/Holder [Re: 44D6PAKCUDA] #2743566
02/16/20 02:12 PM
02/16/20 02:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I made one out of 2x4s. took me all of maybe 2 hours.
Re: Dash Frame Rotisserie/Holder [Re: gtx6970] #2743873
02/17/20 11:00 AM
02/17/20 11:00 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
In my opinion - a waste of time and money unless you're going to do more than a couple. I used one of those body panel sawhorse things with the foam on the bars. Just rolled the dash over as necessary.
https://www.harborfreight.com/200-lb-capacity-portable-work-stand-38778.html
Re: Dash Frame Rotisserie/Holder [Re: Stanton] #2743883
02/17/20 11:20 AM
02/17/20 11:20 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Make something yourself out of wood. They come in handy. I used mine for my Challenger and my Dart. Since both my projects were long term builds, the stand gives me a place to store the completed dash while I work on the rest of the car. When it's not being used for dash storage, I can hang parts off of it to paint. I don't remember how tall it is but I'd guess it's about 4'. The top of the dash is probably at 5'. It all depends on how tall you are and at what height you're comfortable working with. I originally designed it for my Challenger dash. All I had to do to get the Dart dash to fit was add two 2x4 blocks to shrink the inside measurement slightly.
Re: Dash Frame Rotisserie/Holder [Re: burdar] #2744034
02/17/20 08:12 PM
02/17/20 08:12 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
I made this many years ago. it also doubles as a K frame stand and other uses as well. only have this pic on comp. rotates to make working on anything very easy at chest level for me.
HEMI,S ARE FOREVER!!!
Re: Dash Frame Rotisserie/Holder [Re: 1969 HEMI R-T] #2744099
02/17/20 10:49 PM
02/17/20 10:49 PM
West Central Wi.
West Central Wi.
I took a second pic of mine. I have a K on it now. and the White bracket also bolts to my bench if I need to.
Re: Dash Frame Rotisserie/Holder [Re: 1969 HEMI R-T] #2744101
02/17/20 10:50 PM
02/17/20 10:50 PM
West Central Wi.
West Central Wi.
3
Re: Dash Frame Rotisserie/Holder [Re: 44D6PAKCUDA] #2744261
02/18/20 01:21 PM
02/18/20 01:21 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
My brother made this one - 2x4s, a couple of L-brackets, and set on a work table.
Re: Dash Frame Rotisserie/Holder [Re: burdar] #2744391
02/18/20 07:21 PM
02/18/20 07:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Mine was like this, only I put swivel casters on the bottom of it to move around the shop
