Re: AMC 360
[Re: NITROUSN]
#2743365
02/15/20 10:08 PM
02/15/20 10:08 PM
Posts: 43,512 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have a couple of AMC Ambassador wagons with 360's, nothing is the same as Chrysler 360's...
JB Rhinehart, Realist
A-Body's RULE!
Re: AMC 360
[Re: Mattax]
#2743941
02/17/20 01:20 PM
02/17/20 01:20 PM
Posts: 5,894 Florida
Locomotion
Good luck. let us know if they're OK. Some have reported the fit isn't great. You may have to do some fitting. My understanding is the small outer bolts were a change starting in 1979. There was another change in design - which I don't recall but I think its mid 70s.
OMIX had them new with the heat stove. However my experience with OMIX is they don't spend a lot of effort on QC. I decided to rebuild mine.
The exhaust manifold bolts used since late 1969 early 70 are unique. Its was an early change for this generation AMC V-8 and there was service bulletin to dealerships.
Are those bolts drilled hollow? Looks like an extreme race car weight saving trick. But AMC may have done that to make it easier to remove broken bolts. (Keeping the hole for easy-out removal centered?)
Re: AMC 360
[Re: Locomotion]
#2744064
02/17/20 09:03 PM
02/17/20 09:03 PM
Posts: 5,752 ohio
ruderunner
ohio
Yes the bolts are hollow, been that way since the 70's at least.
Angry white pureblood male
