Convert to replaceable air bleeds? #2743168
02/15/20 12:27 PM
02/15/20 12:27 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
Is there enough meat on this carb casting to drill & tap for replaceable idle air bleeds, especially on the primaries? work
I don't know what the thread size is for the available jets, but I could make my own with 6-32 or 8-32 brass set screws.
thanks.
Re: Convert to replaceable air bleeds? [Re: DrCharles] #2743433
02/16/20 07:51 AM
02/16/20 07:51 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
lots of good info herehttps://www.tapatalk.com/groups/racingfuelsystems/index.php:
Re: Convert to replaceable air bleeds? [Re: DrCharles] #2743469
02/16/20 09:57 AM
02/16/20 09:57 AM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
Use a nice sharp drill bit with a decent amount of pressure about .093-..098. The bit will grab and pull it up out. The hole will be too big for 6/32. The problem will be sneaking the tap handle past the air horn. You might as well machine the air horn off.
Woodruff Carburetor Specialties
330-799-9479
Re: Convert to replaceable air bleeds? [Re: Vincenzo] #2743475
02/16/20 10:15 AM
02/16/20 10:15 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They make tap extensions and even extra long taps.
Heck, you probably have some 8 point sockets that you could use to run a tap in your tool box.
Re: Convert to replaceable air bleeds? [Re: Sniper] #2743540
02/16/20 12:44 PM
02/16/20 12:44 PM
moparx Offline
moparx  Offline
those type of castings should be tapped with a form tap.
these kind of taps require larger hole sizes than cut [normal type] taps.
using a form tap will make stronger threads in that type of casting.
beer
Re: Convert to replaceable air bleeds? [Re: moparx] #2743611
02/16/20 03:26 PM
02/16/20 03:26 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I used a spiral tap, very easy to do.
