Page 3 of 5 1 2 3 4 5
Re: 71 GTX [Re: larrymopar360] #2742501
02/13/20 06:28 AM
02/13/20 06:28 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if you ask me $10K might be little low. but for the info i have now it's about right.
after a GOOD inspection maybe higher. there are a LOT of unknowns.
i would look at it this way. $10K buys you a ticket to the dance. but it will cost you another $15K to dance with the hot number across the room.
it will cost you $15K to get it back on the road, if you can do most everything yourself. if you have some good connections on parts deals maybe less. after a good going thru you might find some surprises so it could be more $$.
so in all reality it will cost not $10k but $25K to buy this DRIVING car that still will need a lot of attention to make it nice, depending on how it cleans up. from my experience that dull finish on the fender in the pic, isn't going to clean up with just a buff. this car probably had the sides repainted, that's why the stripe is gone. and it will need a repaint. is it really a smoking deal now?
perception is 90% of reality
Re: 71 GTX [Re: Mr T2U] #2742609
02/13/20 02:55 PM
02/13/20 02:55 PM
RI Deep in the rust belt
chargervert Online content
chargervert  Online Content
The Dana 60, and the 4 speed are worth atleast 5 grand by themselves these days.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 71 GTX [Re: larrymopar360] #2742616
02/13/20 03:22 PM
02/13/20 03:22 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Engine pic
Any idea what that canister with the screw on cap is on PS firewall?
1972 Cuda 340 auto, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 2001 Ram 5.2 4x4 auto, 1996 Ram 5.9 2x4 auto
Re: 71 GTX [Re: cdstl] #2742618
02/13/20 03:28 PM
02/13/20 03:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Windshield washer ?
Re: 71 GTX [Re: stumpy] #2742627
02/13/20 04:49 PM
02/13/20 04:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe for the so called alcohol system???
Re: 71 GTX [Re: NITROUSN] #2742628
02/13/20 04:53 PM
02/13/20 04:53 PM
RI
cudascooter Offline
cudascooter  Offline
RI
Looks like an old Briggs and Stratton gas tank.
Re: 71 GTX [Re: cudascooter] #2742629
02/13/20 05:02 PM
02/13/20 05:02 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
It is & was probably used for the alcohol or water injection, maybe connected to that funky knob by the E/brake.
Re: 71 GTX [Re: cdstl] #2742632
02/13/20 05:08 PM
02/13/20 05:08 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
[quote=cdstl]So now it will be a search for VINs. Engine, Trans and body. I'm used to A and E body.
I can find the VIN on the trans. Is the engine on passenger side rail just above the oil pan? I know that the 69 charger had one on the driver side trunk lip under the weather strip.
Is there another on the radiator support.
Eng. vin on r/side oil pan rail & pad by distributor should have G 440 HP & assembly date close to door sticker month/year, Partial vin# on rad support/cowl by fresh air intake vent & trunk seal channel.
P/S & no P/Brakes the opposite of mine, It would interesting to see if the vin# is close to mine.
Re: 71 GTX [Re: 71GTX471] #2742635
02/13/20 05:23 PM
02/13/20 05:23 PM
Mr T2U Offline
Mr T2U  Offline
there should be a VIN # on the plate directly above the wiper motor. there is a weatherstrip clipped to it. the vin might be under the weatherstrip.
there will be a vin # on the radiator support.
no vin on the trunk.rail under the weatherstrip.
Re: 71 GTX [Re: Mr T2U] #2742639
02/13/20 05:33 PM
02/13/20 05:33 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
no vin on the trunk.rail under the weatherstrip. [/quote]
Did they stop putting the vin under the seal for 71,I assumed they had it I never checked for mine.
Re: 71 GTX [Re: larrymopar360] #2742647
02/13/20 06:22 PM
02/13/20 06:22 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Originally Posted by larrymopar360
Seems hard to imagine $10k isn't a good deal for this car. And a lower offer COULD buy it I'm assuming.
A lot of years have passed, so I wonder if that driver's kick panel could have been swapped out at some point, for whatever reason....who knows after almost 50 years.
Could the factory stripe have been removed without paint damage if owner didn't like it?
I have 2 B-5 Blue interior cars a 71 and a 72 that is an original panel that was sun faded just like the original door panel has faded under the armrest..
Re: 71 GTX [Re: 71GTX471] #2742651
02/13/20 06:33 PM
02/13/20 06:33 PM
Mr T2U Offline
Mr T2U  Offline
i THINK they stopped stamping the vin under the trunk W/strip in 1970 on ALL CARS.
i know there are no vins under the w/strip on E bodies and B bodies. anything else is just a guess.
Re: 71 GTX [Re: cdstl] #2742697
02/13/20 10:18 PM
02/13/20 10:18 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Originally Posted by cdstl
Engine pic
No idea on the canister.
I'd check the engine parts carefully, look at all casting numbers, especially if the original engine is important to you.
And a Carter carb? I think many were Holleys in '71.
looks like manual brakes, drums up front?
Thanks for sharing this very cool car with us, last year for pure GTX!
Good luck!
Re: 71 GTX [Re: Mr T2U] #2742764
02/14/20 08:33 AM
02/14/20 08:33 AM
1970 B body cars still have the VIN numbers stamped under the trunk weather strip on the drivers side,just like 1969 cars do.
Re: 71 GTX [Re: chargervert] #2742948
02/14/20 06:34 PM
02/14/20 06:34 PM
Mr T2U Offline
Mr T2U  Offline
you are right.
i should have posted all NEW body styles after 70 didn't get stamped on the trunk rails under the weatherstrip.
Re: 71 GTX [Re: Mr T2U] #2742956
02/14/20 06:53 PM
02/14/20 06:53 PM
RoadRunnerLuva Offline
To the OP...check out the car's vin#s yet ? popcorn
"Get busy living or get busy dying"....
1972 Plymouth Duster...418ci Stroker Small Block
1973 Dodge Charger SE Brougham...400 Magnum Big Block (SOLD)
1971 Plymouth Duster...360 4bbl (SOLD)
1970 Dodge Challenger...340 4bbl (SOLD)
1969 Dodge Dart...440 Big Block (SOLD) Burn't up in a fire
1969 Chrysler 300 Convertible...440 TNT Big Block
1968 Dodge Dart Custom...318 4bbl (SOLD) Smashed/Wrecked
1998 Dodge Dakota R/T 5.9 Magnum
2002 Jeep Grand Cherokee 4.0
Re: 71 GTX [Re: RoadRunnerLuva] #2743004
02/14/20 08:49 PM
02/14/20 08:49 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Going over in the morning. I would imagine that everything is there from the factory. I'm not sure if I mentioned this, but these folks owned a Dodge dealership and this was one of their toys.
Can't wait.
Re: 71 GTX [Re: cdstl] #2743068
02/15/20 02:05 AM
02/15/20 02:05 AM
Toledo
X
Xgoldfish Offline
Xgoldfish  Offline
X
Toledo
Looks like a great GTX.....hope you get it. Looking forward to seeing it washed.
As for the last pic of the ‘72, six-way seat on passenger side? Do tell.
Re: 71 GTX [Re: Xgoldfish] #2743094
02/15/20 07:25 AM
02/15/20 07:25 AM
Mr T2U Offline
Mr T2U  Offline
i cut apart a drivers side 6 way seat adjuster. flipped the important parts over and welded everything back together.
i did this 15 years ago, so my memory isn't perfect. i do remember flipping and welding the round coil spring in the rear was the hardest part.
it also helped to have a complete 6 way adjuster next to my conversion to compare things..
Re: 71 GTX [Re: cdstl] #2743273
02/15/20 05:35 PM
02/15/20 05:35 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Ok, finally got to go see the car. I met the owner briefly. Evidently he does business in the Far East and he was on the phone with them so he just left me alone with the car, and the kid who is a family friend of his. That was fine because it gave me plenty of time to look things over.
Numbers matching engine and the Dana are there. I couldn't get the car high enough to check the VIN on the trans so, judging by the car, I'm going to assume that it's the matching trans as well. Torque boxes, clutch and brakes are free and the transmission shifts ok. I didn't get to see the trunk floor yet because the owner didn't bring me a key.
It has had rust repair and been repainted a darker color of blue. Door bottoms and rockers are good, some bondo behind the rear wheel wells. It was last licensed in 1981 and no price has been discussed yet.
It would have been cooler to have the original paint, but what are you going to do. My plan all along was to clean and reuse as much of the car as I could. Rebuild a different motor, probably a stroker, throw some Day 2 mods at it and then drive the hell out of it. I'm going to leave the faded, mice eaten beast just the way that she is but she will be fast and reliable.
But first, I need to buy it. I'll try to get a video up somehow.
Holley 2 axis g meter
by AndyF. 02/25/20 01:21 AM
How long does your battery last?
by calmopar. 02/25/20 12:14 AM
Moparts Recent Posts
Is my oil pressure too high?
by Dave_J. 02/25/20 02:57 AM
Proper name for welded bolts ??
by PhillyRag. 02/25/20 02:25 AM
Lost a great one He went by "Supercomp"
by 572B1. 02/25/20 01:50 AM
