Timing light on a gen 3 hemi #2742139
02/11/20 11:04 PM
02/11/20 11:04 PM
Delaware
biff426 Offline OP
biff426  Offline OP
Delaware
Is there any reason a conventional timing light could not be used on a gen 3? I made a pointer and put old school timing tape on the balancer. TDC is exactly marked on the balancer. It "appears" no matter how I set the XIM I have 32 degrees of total timing. Does anyone know if picking up the signal from the coil primary wires would give a false reading?
Re: Timing light on a gen 3 hemi [Re: biff426] #2742172
02/12/20 07:25 AM
02/12/20 07:25 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Should work just fine as long as you have typical sequential spark and not waste spark or something.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 Subaru WRX - E30 Tune ~320whp
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Timing light on a gen 3 hemi [Re: GoodysGotaCuda] #2742264
02/12/20 12:40 PM
02/12/20 12:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Even a waste spark should light up at the same degrees just on the exhaust stroke butt it should light up the balancer the same. If you can't trigger it with the primary side you could get an 03-04 coil and adapter than run the timing light off one leg of the coil grounded out with a dummy plug or something.
Re: Timing light on a gen 3 hemi [Re: HotRodDave] #2742285
02/12/20 01:19 PM
02/12/20 01:19 PM
Delaware
biff426 Offline OP
biff426  Offline OP
Delaware
This is what I thought. The problem is I marked the balancer …...I am 100% sure it is marked at TDC. I made a pointer and checked the timing. No matter where I set the XIM box it shows 32 degrees of timing. I had a buddy send his XIM box and it does the same thing. So now I am not sure what I have here. I am using an MSD timing light. I really just want to verify the timing on this thing it is a siple cam and crank sensor with a carb but I know 32 degrees is about 10 degrees too much.
Re: Timing light on a gen 3 hemi [Re: biff426] #2742393
02/12/20 05:43 PM
02/12/20 05:43 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My MS3X has an option for "Fixed timing" or "Use Table" if fixed timing is selected changes to the table don't do a thing. Does the Fast have anything like this that could be accidentally selected?
68 Barracuda Formula S 340
Re: Timing light on a gen 3 hemi [Re: Bad340fish] #2742425
02/12/20 08:07 PM
02/12/20 08:07 PM
Delaware
biff426 Offline OP
biff426  Offline OP
Delaware
No this thing is like the stone ages. No Support from FAST their answer is send it back we will test it. I explained I tried 2 different boxes same software version and it did the same thing. They talk to you like your stupid. I'm putting an MSD on it and either Summit is taking this junk back or I'm calling my credit card and forcing a credit.
Re: Timing light on a gen 3 hemi [Re: biff426] #2742471
02/12/20 11:51 PM
02/12/20 11:51 PM
Downtown Roebuck Ont
Twostick Offline
Twostick  Offline
Give Mopar_Rich a call.
http://www.fastmanefi.com/
Kevin
Re: Timing light on a gen 3 hemi [Re: Twostick] #2742622
02/13/20 04:00 PM
02/13/20 04:00 PM
Delaware
biff426 Offline OP
biff426  Offline OP
Delaware
Thanks Kevin I called and spoke to Rich. Unfortunately he didn't have any ideas. I am at a loss.
Holley 2 axis g meter
by AndyF. 02/25/20 01:21 AM
How long does your battery last?
by calmopar. 02/25/20 12:14 AM
Moparts Recent Posts
Is my oil pressure too high?
by Dave_J. 02/25/20 02:57 AM
Proper name for welded bolts ??
by PhillyRag. 02/25/20 02:25 AM
Lost a great one He went by "Supercomp"
by 572B1. 02/25/20 01:50 AM
