Re: Timing light on a gen 3 hemi
[Re: biff426]
#2742172
02/12/20 08:25 AM
02/12/20 08:25 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Is there any reason a conventional timing light could not be used on a gen 3? I made a pointer and put old school timing tape on the balancer. TDC is exactly marked on the balancer. It "appears" no matter how I set the XIM I have 32 degrees of total timing. Does anyone know if picking up the signal from the coil primary wires would give a false reading? Should work just fine as long as you have typical sequential spark and not waste spark or something.
[Re: GoodysGotaCuda]
#2742264
02/12/20 01:40 PM
02/12/20 01:40 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Even a waste spark should light up at the same degrees just on the exhaust stroke butt it should light up the balancer the same. If you can't trigger it with the primary side you could get an 03-04 coil and adapter than run the timing light off one leg of the coil grounded out with a dummy plug or something.
[Re: biff426]
#2742393
02/12/20 06:43 PM
02/12/20 06:43 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
My MS3X has an option for "Fixed timing" or "Use Table" if fixed timing is selected changes to the table don't do a thing. Does the Fast have anything like this that could be accidentally selected?
68 Barracuda Formula S 340
