Re: Rear main seal leaks on B.B.
[Re: fastmark]
#2741984
02/11/20 03:29 PM
02/11/20 03:29 PM
Posts: 1,417 Martinsville, IN
cdwmotorsports
Martinsville, IN
I have a block missing one so I’ve been looking at billet ones. 440source has one it’s about $50 for the kit with the bolts. I have not used it and will monitor this.
eBay-cdwmotorsports
[Re: fastmark]
#2741986
02/11/20 03:31 PM
02/11/20 03:31 PM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
There seems to be a trick to getting them not to leak. There are some great threads in the archives on here about numerous people's struggles to get them leak free.
Hughes sells a billet seal holder too. Superformance sells a nice rear seal kit. Also, keep in mind that the two oil pan bolts that thread into the seal holder are shorter than the rest of the pan bolts. Make sure you pre-fit the ones you are going to use to make sure they don't bottom out in the seal holder.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2741989
02/11/20 03:34 PM
02/11/20 03:34 PM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
I've never had any issues using a stock retainer and just offsetting the seal in the cap so the ends of the seal doesn't line up w/ the edge of the retainer. I always use Fel-Pro seals.
[Re: Jerry]
#2742070
02/11/20 08:20 PM
02/11/20 08:20 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I've used stock rear main seal holders for a lot of years on stock blocks and 1 or 2 on after market blocks with no sealing issues. I have several in stock now from broken blocks. I buy the seals in bulk and the last batch, not sure of the manufacturer, had issues on the depth of the sealing surfaces on a race block, I ended up using some of the older main seals I had and they worked good What showed me the problem was there was no marks from the seal edge on the grease I put on the seal surface as a lube, IE no contact with the crankshaft I now installed the seal holder with no side seals and check the seal contact to the crankshaft before adding the side seals I don't stagger the seals either but I try to remember to use a small dab of adhesive silicone between the seal ends
[Re: an8sec70cuda]
#2742173
02/12/20 08:37 AM
02/12/20 08:37 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I've never had any issues using a stock retainer and just offsetting the seal in the cap so the ends of the seal doesn't line up w/ the edge of the retainer. I always use Fel-Pro seals. This is all ive ever done,even on after market blocks and have had goods results.im no pro by a long shot.
[Re: Cab_Burge]
#2742198
02/12/20 10:55 AM
02/12/20 10:55 AM
Posts: 6,363 Abilene, Texas
fastmark
Abilene, Texas
I've used stock rear main seal holders for a lot of years on stock blocks and 1 or 2 on after market blocks with no sealing issues. I have several in stock now from broken blocks. I buy the seals in bulk and the last batch, not sure of the manufacturer, had issues on the depth of the sealing surfaces on a race block, I ended up using some of the older main seals I had and they worked good What showed me the problem was there was no marks from the seal edge on the grease I put on the seal surface as a lube, IE no contact with the crankshaft I now installed the seal holder with no side seals and check the seal contact to the crankshaft before adding the side seals I don't stagger the seals either but I try to remember to use a small dab of adhesive silicone between the seal ends That’s my experience. I had one SB that I never could fix but that was long ago.
[Re: fastmark]
#2742201
02/12/20 11:07 AM
02/12/20 11:07 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I used the Mancini RMS kit. No leaks.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
