High volume water pumps #2741036
02/08/20 07:06 PM
02/08/20 07:06 PM
Norway
General 68 Offline OP
Norway
I wonder if I need a high volume water pump. I have ran two different bb's, 440 and 512 in my car and both experienced the normal 180 temp to rise quite a bit past 200 when idling in heavy traffic and uplining at the track. So far no overheating. Temp cools down when revving or getting up to speed. Two different radiators. First stock 3 row 26". Then alu 2 row with bigger tubes. No change. Run stock water pump, 7 blades I think. Tried different fan clutches. 7 blade oem fan, shroud with the fan about in the middle, 1" distance between clutch an radiator. Playing with timing and mixture makes no difference. What do you think? Any prefered pumps? Was looking at Milodon high volume pump with aluminum housing. Any experience with this pump?
Re: High volume water pumps [Re: General 68] #2741062
02/08/20 08:39 PM
02/08/20 08:39 PM
Washington
madscientist Offline
Washington
Yes. And make sure the pump is turning crank speed or faster.
Re: High volume water pumps [Re: madscientist] #2741065
02/08/20 08:46 PM
02/08/20 08:46 PM
Kirkland, Washington
Pacnorthcuda Offline
I’m running a Flowkooler, best one I’ve tried and I’ve run stockers and Edlebrocks. It won’t solve a cooling system issue caused by a different part, but they do flow well, and it lessened my issue (same as yours) by at least 5 degrees.
Re: High volume water pumps [Re: Pacnorthcuda] #2741093
02/08/20 10:17 PM
02/08/20 10:17 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use a 6 cylinder pulley that is smaller in diameter.Stock aluminum housing and pump with a $200 aluminum Afco rad and single Spal pusher fan. It's all in the combo grin
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: High volume water pumps [Re: hemi-itis] #2741382
02/09/20 09:10 PM
02/09/20 09:10 PM
ma.
duspan Offline
duspan  Offline
ma.
flow kooler water pump also a hi flow thermostat and a upper pulley bigger than bottom pulley or at least same size!
Re: High volume water pumps [Re: duspan] #2741481
02/10/20 09:27 AM
02/10/20 09:27 AM
an8sec70cuda Offline
I've used the Flow-Kooler and Milodon HV water pumps w/ good results. Make you use a high flow/balance flow thermostat like a Robert Shaw.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: High volume water pumps [Re: an8sec70cuda] #2741647
02/10/20 05:20 PM
02/10/20 05:20 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Exact same issues with the wife's 440 Six Pack Challenger.
Not sure if it's a coolant flow or air flow issue or both.
Engine is fresh mild build with stealth heads.
I have the timing set very mild and the carb(s) jetting/adjustment seems good.
Outside temperature is a big factor.
In cooler temps with low humidity no issues anytime.
In hot, humid 85 plus degree weather is when the engine heats up when sitting.
Driving/moving around in any temp it stays at 180 all the time.
When it's hot out if sitting idling or stuck in heavy traffic temps will creep up eventually getting to 200 plus.
As soon as the car gets moving again temp gets back down to 180 pretty quick.
Engine temps always stay at 180 on the highway.
I've tried a high flow 160 thermostat with new factory custom built 26" 4 core radiator using a factory shroud, aluminum pump housing and HD water pump with 7 blade factory fan with no clutch.
Then went with a new aluminum 26" radiator and high flow Flow Kooler water pump with coolant recovery tank/system.
This made a slight improvement but temps still creeped up when sitting at idle on hot days.
So what is working the best is I added a pusher fan in front of the radiator.
I currently have the fan on a toggle switch and turn it on when the engine temp gets just under 200.
The fan gets the engine temp down pretty quick and the temp stays down as long as the fan stays on.
When I do tuning on the car I turn the pusher fan on and can work on the car sitting at idle indefinitely.
I would like to get an adjustable fan controller installed and keep the toggle switch as a backup.
Re: High volume water pumps [Re: KillerBee] #2741805
02/11/20 01:33 AM
02/11/20 01:33 AM
Norway
Norway
Good info! I'll Try av Flow Kopler first, but I have a feeling it also is a fan/air problem.
Re: High volume water pumps [Re: KillerBee] #2741849
02/11/20 09:22 AM
02/11/20 09:22 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Really not hurting anything at 200*. My filled 511 would run 218* going down the road and it never hurt anything. I was using Evans coolant and a good oil (Amsoil) at the time. Had Milodon HV water pump and twin electric spal fans. If I stopped, the temp would pull right back down to the 200 range. I removed the electric fans and reinstalled flex fan with shroud and temps would stay in the + or - 200 range depending on air temp. I reinstalled bigger electric spal fans for this next season. Will see how it goes. Yeah, 200* I wouldn't worry about. Put some Evans waterless coolant in there and no worry about boil over til 374* or in our world, never.
Re: High volume water pumps [Re: mopar dave] #2741954
02/11/20 02:19 PM
02/11/20 02:19 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The Edelbrock pumps with the long curved blades move a lot more fluid for each rotation vs the stock type straight blade pumps. They are $$$, but do work well.
The high flow T-stat is a must do item with these.
Re: High volume water pumps [Re: Neil] #2741981
02/11/20 03:20 PM
02/11/20 03:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
What are you guys calling a "high flow" thermostat? Pictures will help help
Re: High volume water pumps [Re: Cab_Burge] #2741987
02/11/20 03:31 PM
02/11/20 03:31 PM
Also called balance flow.
CHIP
Re: High volume water pumps [Re: an8sec70cuda] #2742197
02/12/20 10:38 AM
02/12/20 10:38 AM
moparx Offline
moparx  Offline
i second the 200+ [a little] as no concern.
beer
Re: High volume water pumps [Re: moparx] #2742334
02/12/20 03:50 PM
02/12/20 03:50 PM
Norway
Norway
Sure 200 + some won't hurt anything. It is more a peace of mind thing. I will never be happy with 200+ and still creeping temps when stuck in traffic or lining up at the track😋
