Re: Steering Stability
[Re: W.I.N. Racing]
#2740095
02/05/20 07:30 PM
02/05/20 07:30 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Here’s the printout from the alignment shop. Yes, with a modified suspension some tweaks are in order. There’s a guy on the west side of town that does a lot of street rod suspensions as well as lowered vehicles. I’ll give him a shout.
Abe Lincoln
[Re: NITROUSN]
#2740115
02/05/20 08:07 PM
02/05/20 08:07 PM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
3 degrees positive caster from a stock type suspension is pretty hard to get, let alone from a lowered truck. Your numbers don't look bad and from what you describe I would suspect something more like a tire problem. Can you swap some wheels and tires from a known good driver?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2740127
02/05/20 08:42 PM
02/05/20 08:42 PM
dart4forte
Mesa, Arizona
I have the front end up and plan to check the front wheel bearings and swap tires. I pretty much ruled out an out of round wheel in that when they were balanced a wheel is sure would of showed up.
Abe Lincoln
[Re: dart4forte]
#2740497
02/06/20 08:43 PM
02/06/20 08:43 PM
Guitar Jones
I have the front end up and plan to check the front wheel bearings and swap tires. I pretty much ruled out an out of round wheel in that when they were balanced a wheel is sure would of showed up. Yeah a wheel would have showed up but may still balance OK. Maybe the guy operating the balancer didn't give [censored]. A broken belt in a tire may not have shown up or refer back to the original guy running the balancer. I seriously doubt that since your issue only manifests at a certain speed ( and a low speed at that) and then clears up that you have an alignment issue.
[Re: Guitar Jones]
#2740567
02/07/20 01:49 AM
02/07/20 01:49 AM
dart4forte
Mesa, Arizona
I have the front end up and plan to check the front wheel bearings and swap tires. I pretty much ruled out an out of round wheel in that when they were balanced a wheel is sure would of showed up. Yeah a wheel would have showed up but may still balance OK. Maybe the guy operating the balancer didn't give [censored]. A broken belt in a tire may not have shown up or refer back to the original guy running the balancer. I seriously doubt that since your issue only manifests at a certain speed ( and a low speed at that) and then clears up that you have an alignment issue. I agree
Abe Lincoln
[Re: dart4forte]
#2742890
02/14/20 03:52 PM
02/14/20 03:52 PM
dart4forte
Mesa, Arizona
Ok, earlier in the week I cut out the angle iron that someone welded to the frame connecting to the core support. Then installed the steering box bracket. Took it out for a drive around side streets the the freeway. Wobble I’d gone. I will pursue adding a little more camber or castor. Also, the going to do some boxing in The vicinity of the box.
Abe Lincoln
