Sprung weight, the portion of a car’s mass that rides on the suspension, is a huge factor in any vehicle’s overall performance because it affects everything from acceleration to traction to fuel efficiency. The less heft an engine has to haul around, the better off you, your suspension, and your drivetrain will be. Additionally, the more weight you can remove from the front end of a vehicle, the better your weight transfer to the rear wheels will be when that skinny pedal hits the floor.
Read the whole story at Mopar Connection Magazine HERE:
