69 Coronet R/T hood?
#2739152
02/02/20 07:45 PM
02/02/20 07:45 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
did the hoods have anything different than a stock hood for the scoops? did they just take a stock hood and drill holes in it and added scoops?
Hell Hath No Fury Like Mine
Re: 69 Coronet R/T hood?
[Re: Diego (not Ted)]
#2741471
02/10/20 06:53 AM
02/10/20 06:53 AM
Posts: 1,567 Ky
jt4406
Ky
The support structure (underside that you are referring to) is most likely the same BUT it received EXTRA cutouts (during the stamping process) that removed material where the scoups mount that allowed the air to flow from the scoups to the ductwork. If you compare the underside of a flat hood to an original N96 hood, it's obvious, not so much with the ductwork installed. A sharp eye will spot a converted flat hood due to this. Some of the cutouts lay flat against the hood skin and personally I see no way of removing the material to duplicate the factory cutouts without removing the top skin first. Anyone done this successfully? I'd wager 99% of all who looked at it would not know the difference. Just my .02, jess.
Yeah, it's hopped up to over 160...
[Re: mrob]
#2741490
02/10/20 09:52 AM
02/10/20 09:52 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
Which makes me wonder if someone made a template
#2742404
02/12/20 07:58 PM
02/12/20 07:58 PM
Posts: 329 N.Y.
VZCharger
N.Y.
When I got a factory Ramcharger hood for my 69 I checked it against my original flat hood. I found that the notches and holes for the scoops and duct work were present on the support structure of the flat hood, just the scoop holes on the top were missing. A friend took my flat hood to replace his original Ramcharger hood that got ruined during blasting. I think that once the Ramcharger system became available they changed the support structure of all hoods.
70 Charger blown injected BB
07 Charger Daytona Plum Crazy #389
69 Coronet ragtop
96 Ram "Garlits Edition"
88 Conquest TSi
[Re: sixpacksteve]
#2744137
02/18/20 01:15 AM
02/18/20 01:15 AM
Posts: 18,153 Mass
DAYCLONA
Mass
Which makes me wonder if someone made a template ......for future reference
