400 to 440 upgrade, now shift problems #2739737
02/04/20 07:23 PM
02/04/20 07:23 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Had a fresh 727 tranny with about 10000 miles behind a cast crank 400 (external balance). We upgraded to a fresh steel crank balanced 440 with Holley Sniper and changed convertor to stock internal balance part. We dropped the tranny pan and found clean fluid and pan. Did not even change the filter. But the new setup has sluggish 1/2 shift and a small flare up and 2/3 shift. We know we have a solid trans SO it has to be:
Kickdown linkage which controls pressure, I would think the linkage from 400 to 440 are different. I have the 440 on the car and may pull to check against the one off the 400. One has the adjustment at the bottom with a jam bolt in a block with a spring. The other is fixed on bottom and has a slotted rod up at carb linkage. HodgePodge of parts. The changes are 400 to 440, Tquad to Sniper, the convertor which looked new and of course we now have more power. I read we need 1 to 1 ratio on this kickdown deal. Should I just go with an aftermarket cable setup?
76 Cordoba 400 and now a 73 New Yorker 440 with a Holley Sniper on a 74 727??????? I need a vacation! Can not dyno tune until I get this tranny back like it was.
What is the correct kick down lever setting on a stock 440? Thanks Stephen
CALMED THE QUAKE!!!(AGAIN!)
Re: 400 to 440 upgrade, now shift problems [Re: Spyphish] #2739775
02/04/20 09:13 PM
02/04/20 09:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You just need the kick down linkage for the 440. The 440 block is taller then the 400 block, so the 400 linkage will be too short. As far as the 440 linkage being adjustable at the top or the bottom shouldn't make any difference as long as the entire 440 linkage system is used. Gene
Re: 400 to 440 upgrade, now shift problems [Re: Spyphish] #2739854
02/05/20 08:09 AM
02/05/20 08:09 AM
Lexington NC
twinscrew698 Offline
Lexington NC
If it was mine i would go with a cable style kickdown.
Re: 400 to 440 upgrade, now shift problems [Re: twinscrew698] #2739876
02/05/20 09:47 AM
02/05/20 09:47 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Just ordered a Bouchillon
Re: 400 to 440 upgrade, now shift problems [Re: Spyphish] #2739947
02/05/20 01:03 PM
02/05/20 01:03 PM
moparx Offline
moparx  Offline
up glad it wasn't a lokar setup.
beer
