Leaf spring inboard kit Mopar #2738768
02/01/20 05:00 PM
02/01/20 05:00 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys I move my original shackles back by a quarter inch front leaf spring With spacers
My question is I have the buckets from Mopar performance I’m Looking for a measurement that you guys are using from the back of a bucket to the center of the leafspring eye
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2738774
02/01/20 06:07 PM
02/01/20 06:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Make my own. Fit them in the car first. Transfer the stock location from the original hangers. Put the holes where I want from there. Usually moved forward a bit if they are moved at all. Along with some locations for height adjustment. Verify square and level when putting them in for final assembly.
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2738799
02/01/20 07:26 PM
02/01/20 07:26 PM
AndyF Offline
AndyF  Offline
Put the hole where it needs to be. I realize that answer might not seem to be helpful but it is the correct answer. It all depends on ride height and tire size and where you want the wheel in the fender and all of that. Mock it up, measure it 5 or 6 times then drill it. It isn't easy making sure that each side is perfectly straight and square to the chassis.
Re: Leaf spring inboard kit Mopar [Re: AndyF] #2738828
02/01/20 08:53 PM
02/01/20 08:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A few things to keep in mind when setting spring-eye locations:
1. Tire clearance can be pretty tight at the front of the wheel opening. Depending on tire OD, what you're building, & whether you're open to stretching the wheelhouse, spend some quality time with a tape measure.
2. I've found A -bodies vary at the front of the wheel house from car to car, and sometimes even side to side on the same car.
3. The rear spring shackles MUST point rearward at the bottom to avoid binding the springs.
If you're trying to stuff 30-31" tires into a Duster, pie-slicing the bottom of the front just forward of the flange and moving the flange forward flush with the wheelhouse can buy you that space.
When it's finished off, it looks very stock.
The same deal probably works on B & E bodies as well.
For a drag car, I've always liked moving the rear axle forward a bit if possible... whistling
Re: Leaf spring inboard kit Mopar [Re: topside] #2738837
02/01/20 09:31 PM
02/01/20 09:31 PM
CA.
CA.
I was moving it back a 1/4inch to help with tire clearance I’m also mini tubing the car. Putting a 10inch rim on the car
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2738846
02/01/20 10:47 PM
02/01/20 10:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
Trim or bend the front edge of fenders to make more tire clearances, DON'T move the rear end back tsk twocents
Re: Leaf spring inboard kit Mopar [Re: Cab_Burge] #2738853
02/01/20 11:02 PM
02/01/20 11:02 PM
CA.
CA.
Really!!!! Ok for weight transfer reasons!?
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2738872
02/02/20 12:31 AM
02/02/20 12:31 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup. Pitch rotation is a lovely thing.
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2738886
02/02/20 02:00 AM
02/02/20 02:00 AM
Moving the rear end back to make tire clearances adds more weight onto the front tires allowing the rear tires to spin easier, correct tsk work shruggy
Re: Leaf spring inboard kit Mopar [Re: Cab_Burge] #2738887
02/02/20 02:52 AM
02/02/20 02:52 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Well SeaBee work ... scope you could always move wrenchthe gas tank further to the rear to compensate up Santa4
Re: Leaf spring inboard kit Mopar [Re: Cab_Burge] #2738917
02/02/20 09:24 AM
02/02/20 09:24 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
I did the trim the fender and put the springs at the stock location with the spring relocation kit.
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2739033
02/02/20 02:22 PM
02/02/20 02:22 PM
AndyF Offline
AndyF  Offline
On my Duster project the original chassis shop screwed up the job. The boxes were built out of tin foil and the holes were drilled crooked. I had to take the car to a different shop where they used heavy duty steel boxes and they put the holes in the correct place. They had to cut the old boxes out of the car and grind everything flat and start over. That was a dirty nasty job. Good thing I didn't have to do that work! In the end it came out okay but it will never look pretty since the rework job left some scars.
Re: Leaf spring inboard kit Mopar [Re: AndyF] #2739114
02/02/20 05:43 PM
02/02/20 05:43 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
AndyF do you run spacers also on your set up. I would rather shorten the wheel base or have the front hanger in the stock location but if you need room do what you must but don't over move it back.
1971 HEMI E BODY REGISTRY
Re: Leaf spring inboard kit Mopar [Re: hemicar1971] #2739391
02/03/20 06:42 PM
02/03/20 06:42 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I machine some 1/4" steel ones for my own car, which was way too heavy. I laser cut some 1/8" steel ones for a friends car, and doubler plates around the bolt holes. Worked out really well.
Personally, I don't see a point in going thicker than 1/8" if it's being welded in to the original rail. The factory sheet metal is going to be the weakest link.
Alan Jones
Re: Leaf spring inboard kit Mopar [Re: hemicar1971] #2739410
02/03/20 07:34 PM
02/03/20 07:34 PM
I've had the front spring hangar moved into the sub frames on four different cars, first was a 1963 Plymouth Belevedere that we center the Mopar kit like the instruction said to do, the third one was on my1971pump gas Duster that I had the boxes moved all the way into the sub frames so the outer edge of the new boxes where welded against the outer frame rail to get as much additional clearances as I could on that car. The second car I ahd done was 1969 Dart and I had the inner edge of the boxes welded into the inner edge of the stock sub frames to get clearances between the stock gas tank and the leaf springs on the passenger side, I still had to dent the gas tank for additional clearances hammer
The last one was on my 1966 Dodge Coronet and I helped a friend, a pipe line welder move those boxes all the way in also after denting the new gas tank for spring clearances on the passenger side hammer up
Re: Leaf spring inboard kit Mopar [Re: Cab_Burge] #2739515
02/04/20 01:22 AM
02/04/20 01:22 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Some of the work we did on my son's 68 Dart 270.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Leaf spring inboard kit Mopar [Re: Dave_J] #2739518
02/04/20 01:26 AM
02/04/20 01:26 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
And after welding the kit in I braced it with gussets.
65 Formula S Cuda
Re: Leaf spring inboard kit Mopar [Re: Dave_J] #2739519
02/04/20 01:43 AM
02/04/20 01:43 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
We cut the front of the wheel well and moved it forward 2 inches. He is running 325/45 20's in the back on Foose Mags
65 Formula S Cuda
Re: Leaf spring inboard kit Mopar [Re: AndyF] #2739549
02/04/20 09:23 AM
02/04/20 09:23 AM
CA.
CA.
Did you guys drill 5/8 holes or 11/16 ?
Re: Leaf spring inboard kit Mopar [Re: RAY1969CARS] #2739555
02/04/20 09:42 AM
02/04/20 09:42 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
For the front spring eye bolts? Mine are 5/8".
