Re: Bad over-the-counter bigblock motor mounts.
[Re: cdp]
#2739177
02/02/20 09:29 PM
02/02/20 09:29 PM
Posts: 2,085 New Mexico
JMCFAN
New Mexico
Anyone have problems with replacement 70/71 bigblock B-body motor mounts?
I've purchased 2 sets, Pioneer off Amazon, and Oriellys brand. Both are the same issue (appear to be same supplier). Thru bolt holes/nut on motor mount are 1/4" off when compared to the originals (3/4. Due to this, the engine does not seat fully on the K-member pad. I went to Rock Auto and found 4 to 6 versions. Upon viewing the 3d views, you can clearly tell the thru holes are out of location. Yes...1st set I purchase had my motor sit shifted ...after checking you could see the difference... bought a good set from Brewers...
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: Jim_Lusk]
#2739209
02/02/20 11:12 PM
02/02/20 11:12 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Offshore trash. So hard to find decent stuff anymore.
[Re: cdp]
#2739211
02/02/20 11:20 PM
02/02/20 11:20 PM
Posts: 1,800 North Dakota
Azzkikrcuda
North Dakota
Most of the new mounts are junk now. I have been using NOS mounts lately. They cost more but fit and hold up better.
The only Carbs I care about are under the hood!
