Cuda Road Lamps ? #2737483
01/28/20 06:19 PM
01/28/20 06:19 PM
michigan
440whiteboy Offline OP
michigan
Cuda Road Lamps question -
I plan to list these for sale so how can I tell what year the bezels are ?
they were removed from my 70 cuda that I had years ago.
numbers on the housings must be 1970 -
should they have a part number on the chrome bezels ?
1) Housings - F 70 B CC 1970 ?
2) Bezels - ?
3) Lamps - GE 4415 F 75 1975 ?
4) Brackets - brackets have L - R
They only see Stars...
when hit by a Mopar!
Re: Cuda Road Lamps ? [Re: 440whiteboy] #2737513
01/28/20 08:00 PM
01/28/20 08:00 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
All looks original to me.That's the right bulb but must have been replaced at some time.
Price wise I would think $300.00 -$400.00 twocents
Re: Cuda Road Lamps ? [Re: 5carguy] #2737567
01/28/20 11:47 PM
01/28/20 11:47 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
70 and 71 used the very same roadlamp assembly, both say SAE-F-70B on the housing, wiring and bezels are the same for both years.
The difference is in the mounting bracket.
1971 is one a piece bracket and slightly different configuration than the 1970 bracket,
which is what you have,... is two piece and welded together.
Re: Cuda Road Lamps ? [Re: mccannix] #2738714
02/01/20 01:11 PM
02/01/20 01:11 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The bezels, if original, have the part number cast into the inside of each bezel on a flat area: 3403845. Original, from the factory bulbs would be Westinghouse units, not GE.
Re: Cuda Road Lamps ? [Re: m46rat] #2739127
02/02/20 06:08 PM
02/02/20 06:08 PM
michigan
michigan
it always helps to know what to look for and where beer
thanks!
