Re: New engine break in
[Re: Hemi ragtop]
#2738322
01/31/20 07:49 AM
01/31/20 07:49 AM
Posts: 287 PA
Harry's Taxi 2
PA
Could you explain that "ring finish designed for synthetic oil"?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Harry's Taxi 2]
#2738338
01/31/20 10:12 AM
01/31/20 10:12 AM
Posts: 2,646 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I think Cab said it perfect. On both counts. If you torqued the intake perfectly (most people don't) it will loosen up after a few heat cycles. Keep torquing it down monthly until it quits asking for more.
2011 Drag Pak Challenger
[Re: Lee446]
#2738373
01/31/20 11:58 AM
01/31/20 11:58 AM
Posts: 1,707 central il.
second 70
central il.
All I can say is that switching to Superformance intake gaskets made all my intake problems go away. No more Fel-Pro, Mr. Gasket, etc. and constant battles with retorquing. I agree my results too.
#2738505
01/31/20 08:26 PM
01/31/20 08:26 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Could you explain that "ring finish designed for synthetic oil"? Bob Myer at Performance Automotive contacted Sunnen about this. They provided the proper stones and speeds and feeds for a finish to accommodate synthetic oil
[Re: Cab_Burge]
#2739276
02/03/20 10:24 AM
02/03/20 10:24 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
[Re: Hemi ragtop]
#2739548
02/04/20 09:20 AM
02/04/20 09:20 AM
an8sec70cuda
Like Cab said already...I'd run regular oil for one oil change interval and then switch to synthetic.
[Re: Hemi ragtop]
#2739554
02/04/20 09:39 AM
02/04/20 09:39 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
Mabie I didn’t pose the question properly. I wondered how many miles I needed to put on the engine before I switched it over to full synthetic oil? Again, it has been Brocken in on dyno and three power pulls. I'm thinking Bob Myer in consultation with Sunnen might be a good source for the time to switch over..
[Re: Hemi ragtop]
#2741865
02/11/20 10:17 AM
02/11/20 10:17 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Mabie I didn’t pose the question properly. I wondered how many miles I needed to put on the engine before I switched it over to full synthetic oil? Again, it has been Brocken in on dyno and three power pulls. The Joe Gibbs break in oil is supposed to be run after the dyno for I believe another 500 miles. Re-read their product spec sheet. Then I believe you can switch to what you want.
[Re: Hemi ragtop]
#2741869
02/11/20 10:29 AM
02/11/20 10:29 AM
Posts: 17,845 S.E. Michigan
ZIPPY
S.E. Michigan
Engine looks really nice Since you had an experienced builder do it, why not ask them what they recommend and follow their whole program.
Rich H.
Esse Quam Videri
