Magnum 360 stroker questions
#2737900
01/29/20 10:22 PM
01/29/20 10:22 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm helping a friend rebuild his smallblock and it needs pistons so we were thinking of getting a stroker kit for it. I am not sure what the difference between a Magnum and an LA 360 is as far as rotating assembly goes. I have done some research here and most of the information is 5-10 years old. I did find that people advised to stay away from the Eagle cast crank but the Scat parts are good. Is there any new information out there on 360 Magnum stoker kits? I would like to know who has the good stuff and who to buy it from. There is a company called Clegg that seems to have a good rep for engine parts anybody ever deal with them? Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Magnum 360 stroker questions
[Re: Ody1003]
#2738003
01/30/20 09:45 AM
01/30/20 09:45 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Check the link below, some good info there. The guy who made the webpage was a member on FABO for a while, maybe here too. His Dart was quick for what it was. http://www.magnumswap.com/
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2738009
01/30/20 09:58 AM
01/30/20 09:58 AM
RMCHRGR
Spahn Ranch
What type of build up is it going to be? Budget or...? The factory stuff is pretty stout so if its just for street you can probably re-use whatever is viable beyond the rotating assembly.
There are inexpensive stroker kits available from anywhere though - Hughes, Mancini, Marsh, Indy, Summit, etc.
If you go with new iron heads the EQ are hard to beat but not sure they are available anymore? Edelbrock makes Magnum-specific heads, or at least they used to.
[Re: Hellrico505]
#2738986
02/02/20 12:13 PM
02/02/20 12:13 PM
fourgearsavoy
Rittman Ohio
Thanks a lot guys for the tips it seems there is enough different things about the Magnum I better get a book about them. I have talked to a local Mopar engine builder and he told me they run really strong but the factory Magnum heads are a little too small for a 408 engine to make good power. The Edelbrock Magnum heads are designed to use small block Chevy which is a plus because you can get a decent set of rockers without spending $600-800. My buddy wants to get into the low 12's or high 11's with a smallblock in a 71 Road Runner and from what I've been reading it's possible with a 408 and some good heads. Gus
[Re: fourgearsavoy]
#2739180
02/02/20 09:35 PM
02/02/20 09:35 PM
Posts: 2,521 PA
moparacer
PA
I have a 402 cid magnum engine in a 67 Barracuda with cleaned up stock heads that runs 11.20s with a mild hydraulic roller cam and 3.55 gears in it so you can definitely get high 11's in a Road runner I bet. You will be RPM limited with the heads though. I shift at 5800 and cross at 5800.
With a set of good aftermarket heads and more gear mine would run high 10's easy.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: viperblue72]
#2739513
02/04/20 01:14 AM
02/04/20 01:14 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
The ATK 410 5.9 Magnum short block has 4.040" KB pistons, Scat 4 inch cast crank, Scat I beam rods. Pistons are D dished and the quench shelf is positive above the deck. I have not measured it yet. I will be doing 'Clay' testing when I put the heads on.
For $2500 it is a well thought out hunk of iron. The compression will be around 10.2:1 with the Edelbrock aluminum heads.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: fourgearsavoy]
#2739615
02/04/20 12:25 PM
02/04/20 12:25 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I'm helping a friend rebuild his smallblock and it needs pistons so we were thinking of getting a stroker kit for it. I am not sure what the difference between a Magnum and an LA 360 is as far as rotating assembly goes. I have done some research here and most of the information is 5-10 years old. I did find that people advised to stay away from the Eagle cast crank but the Scat parts are good. Is there any new information out there on 360 Magnum stoker kits? I would like to know who has the good stuff and who to buy it from. There is a company called Clegg that seems to have a good rep for engine parts anybody ever deal with them? Thanks Gus What I would do is get the heads he wants, cc them, put them on the block to see if they and the intake fit, and determine how much milling you can do to fix the compression if you get the wrong piston in a kit. My edlbrocks are 58cc exact, others have reported some as high as 62. What little I have messed with the magnum the 1.46 compression height piston will be .005ish in the hole, Icon makes a magnum head piston at 1.465 ch, with valve reliefs, but compression is 13.5. My pistons are 1.46 ch, 28cc dish, 9.84 to 1, after a .010-.015 head mill it will be 10-1. My block is almost mirror deck finish, but the heads are rough, not confident the cometic gaskets will seal, only reason to mill them. Nobody around here can do much less than .010. Your biggest issue is getting the compression right, so pick a head and piston first and mock the block up, that way you are not milling the block, unless it is crooked, doubtful on a magnum, then the pistons, then the heads, that wastes$$$. I never buy anything internal till I put the heads and intake on and cc the heads anymore, I have learned. The only other issue is h-beam mopar rods need an eyebrow bore notch, I am told if you order the kit with chevy journals it does not. Plenty of pistons out there just do your math.
[Re: 4406bbl]
#2739831
02/05/20 01:36 AM
02/05/20 01:36 AM
Dave_J
Auburn WA
What I would do is get the heads he wants, cc them, put them on the block to see if they and the intake fit, and determine how much milling you can do to fix the compression if you get the wrong piston in a kit. My edlbrocks are 58cc exact, others have reported some as high as 62. What little I have messed with the magnum the 1.46 compression height piston will be .005ish in the hole, Icon makes a magnum head piston at 1.465 ch, with valve reliefs, but compression is 13.5. My pistons are 1.46 ch, 28cc dish, 9.84 to 1, after a .010-.015 head mill it will be 10-1. My block is almost mirror deck finish, but the heads are rough, not confident the cometic gaskets will seal, only reason to mill them. Nobody around here can do much less than .010. Your biggest issue is getting the compression right, so pick a head and piston first and mock the block up, that way you are not milling the block, unless it is crooked, doubtful on a magnum, then the pistons, then the heads, that wastes$$$. I never buy anything internal till I put the heads and intake on and cc the heads anymore, I have learned. The only other issue is h-beam mopar rods need an eyebrow bore notch, I am told if you order the kit with chevy journals it does not. Plenty of pistons out there just do your math. If you get the 4 inch stroke Scat Crank and Scat PRO SERIES I-BEAMS rods it clears the block, NO GRINDING. These rods have smaller bolt heads with no nut.
[Re: Dave_J]
#2739998
02/05/20 02:45 PM
02/05/20 02:45 PM
Posts: 403 Colorado front range
BcudaChris
For $2500 it is a well thought out hunk of iron. The compression will be around 10.2:1 with the Edelbrock aluminum heads. For sure, and I landed at the same measured static compression. EQ heads and the chambers ended up at 69cc. If you get the 4 inch stroke Scat Crank and Scat PRO SERIES I-BEAMS rods it clears the block, NO GRINDING. These rods have smaller bolt heads with no nut. Yeah, had my block at the machine shop and notched before my kit arrived. My research and questions failed me on this item. On the plus side though, the block is ready for a longer arm if I'm so inclined.
Last edited by BcudaChris; 02/05/20 02:46 PM. Reason: to coverup borderline illitaracy
[Re: BcudaChris]
#2740187
02/06/20 12:01 AM
02/06/20 12:01 AM
fourgearsavoy
Rittman Ohio
Well some real world information here that I was looking for. My buddy decided on an Eagle forged crank and Eagle rods with Diamond dished pistons designed for the Magnum engine. It was more expensive than a "kit" but he was thinking of maybe hitting it with some spray in the future so I know the forged Eagle crank will be good. The block will be at the machine shop for a while so it's going to be a few weeks until we get it back. Decided to go with the factory heads and just clean up the bowls and smooth out the pinch Going with a mild cam with some good torque to get the B-body rolling. Thanks again for all the insight and information Gus
[Re: dvw]
#2740423
02/06/20 05:13 PM
02/06/20 05:13 PM
Dave_J
Auburn WA
the heads are rough, not confident the cometic gaskets will seal, only reason to mill them. Nobody around here can do much less than .010. You need to find a real machinist. We've skim cut heads .002" without issue. Doug [/quote] +1When I had my 318 block decked they did a 'KISS' cut at 0.002" and it only touched in 3 places. They had to do 0.010 before it was even close to fresh metal. It took 0.020" to equalize both decks so not too bad and I had a total of 0.030" taken. So yes they CAN do 0.002" if they are not lazy. But will 0.002" clean up the surface in 1 wack?
[Re: Dave_J]
#2770229
05/01/20 06:23 PM
05/01/20 06:23 PM
fourgearsavoy
Rittman Ohio
Well the owner decided on the Edelbrock heads and I found a cam that I think should work good for this mainly street car. It's a Howard's hydraulic roller Lift: .507 / .533, Duration @ .050: 221 / 225, Centerline: 108, Mild idle, Street performance, Big low end torque, Should have 9.0:1+ compression & 1800+ stall converter. It should make plenty of steam to push his car in the low 12 high 11's Gus
