Re: Broke off Dipstick, Help needed
[Re: dOc …]
#2737870
01/29/20 08:57 PM
01/29/20 08:57 PM
Posts: 5,956 ohio
ruderunner
ohio
Tubes don't have handles.
Personally, knock it into the pan and put another tube in.
Angry white pureblood male
[Re: ruderunner]
#2737875
01/29/20 09:13 PM
01/29/20 09:13 PM
Posts: 275 Oakwood Ont Canada
340mouse
Oakwood Ont Canada
Personally, knock it into the pan and put another tube in. What will happen when it is in the pan!!! Man, I gotta be the worlds worst DIY mechanic.
[Re: 340mouse]
#2737901
01/29/20 10:25 PM
01/29/20 10:25 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
Is it the dipstick or the tube? If it's the tube and it turns, a tap probably won't work. How about a small 90 degree pick.
11B40
[Re: JonC]
#2737916
01/29/20 11:03 PM
01/29/20 11:03 PM
340mouse
Oakwood Ont Canada
Is it the dipstick or the tube? If it's the tube and it turns, a tap probably won't work. How about a small 90 degree pick. Ya sorry, it is the tube that broke off, the wife suggested a crochet hook,
[Re: 340mouse]
#2738049
01/30/20 12:00 PM
01/30/20 12:00 PM
Posts: 1,612 westerly, ri. usa
440lebaron
westerly, ri. usa
DENT puller with a self tapping screw
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2738053
01/30/20 12:14 PM
01/30/20 12:14 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
What GTX6070 said. I just did one a couple of weeks ago on a 318, I barely tapped the tap in with a hammer and pulled it out with vise grips, worked like a charm!
[Re: Lee446]
#2738062
01/30/20 12:27 PM
01/30/20 12:27 PM
Posts: 11,731 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
360? Stock pan? Don't they have a dipstick guide welded in the the pan? Knock the thing down in and you probably won't get the stick to go in.
If it turns, a tap will go in so far before it starts to turn the stub. At that point, turn and pull at the same time. It may come out. Otherwise drop the pan.
[Re: 340mouse]
#2738171
01/30/20 06:23 PM
01/30/20 06:23 PM
Posts: 30,491 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Personally, knock it into the pan and put another tube in. What will happen when it is in the pan!!! Man, I gotta be the worlds worst DIY mechanic. Tubes ? .. he’s talking about the STICK ..not the tube I’ve had to do this same operation on a 3.8 V6 .... Just pull the tube out of the block and then push the broken stick out !
