Has anyone tried the trick flow cam or combos? #2737579
01/29/20 12:42 AM
01/29/20 12:42 AM
junction city oregon
V
viperblue72 Offline OP
V
Has anyone used the trick flow cam or combo? I’m thinking of trying this cam in my ramcharger.
It’s 243/247@050 and ,600/.600 on 108lsa. My current cam is 230/239 .525/.540 on 112. It made 490/554tq but I want to maximize my combo. I used dyno sim 2000 and it comes up with almost my exact numbers but when i put in the other cam it shows 100hp more. I know that’s optimistic but what are your thoughts?
Re: Has anyone tried the trick flow cam or combos? [Re: viperblue72] #2737593
01/29/20 02:34 AM
01/29/20 02:34 AM
AndyF Offline
AndyF  Offline
We've run a couple of engines with the full Trick Flow top end kit. They both made really good power. Trick Flow dyno results are around 600 hp using their top end kit on a pump gas 440 and from what I've seen I'd say that is accurate.
Re: Has anyone tried the trick flow cam or combos? [Re: AndyF] #2737665
01/29/20 12:06 PM
01/29/20 12:06 PM
V
V
Thank you Andy. I’m running ported sidewinders that if I were to guess flow about 300cfm. So I probably won’t make what the trick flows do power wise and I have a perf rpm intake. I’ll be happy if it makes 550 but it should make a little more I would guess.
